So this winter I have a small list of things to address, first is a drivers door solenoid that sicks on occasion, I pull the door panel & check the solenoid cable than made sure of a good ground ,than pulled the two relays,& found discolored posts on them ,changed out for new & all's good again! Next up is a drivers window not going all the way up, the window rubber seems out of shape so a call to Toyota has a new one coming & will see if that is the cause. More to come !
