Another matinance repair
Discussion in 'Maintenance/Repair' started by TRUCK ACTION, Mar 8, 2018.
  1. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    So I got my AC up & working back in 2014 ,only used it a few times on some long trips to shows. Last time I turned it on the pump clutch wasn't engaging thought a bad compressor, so tested the other day will engage if 12volts is feed to it,so suspect the system is low & the low pressure switch is open.
    Today will test for any present pressure than evacute the system & recharge,hope this fixes the problem.
