And here.... we... go.
Discussion in '1989-1995 Build-Up/Project Threads' started by Litneon, Mar 26, 2010.
  1. REDZ
    REDZ Enthusiast
    vid not working lit:shrug:
  2. jblaust
    jblaust Veteran
    Miami, FL
    1994 Pickup Standard Cab Base 22RE Manual
    Bad ass!
  3. first80toyota
    first80toyota Addict
    Pacific Northwest
    '77 Hilux
    It worked just fine for me? It shows up a black square until I click on it, then it plays..
  4. Litneon
    Cocoa, FL
    94 xtra cab
    Yeah, it's odd. It showed up as a black rectangle, but when I clicked on it, it played. Not sure why the link is acting up now.
  5. REDZ
    REDZ Enthusiast
    i can only watch it on ma tablet its seems haha .. what size fuel injectors are you using
  6. Litneon
    Cocoa, FL
    94 xtra cab
    I have the Injector Dynamics ID1000's.
    I'm currently at 65% duty cycle, but I found that this is due to the fact that my Walbro 255 isn't building more than 57 pounds of fuel pressure. It should be up around 65 psi with this regulator. So it's like running 29 psi of fuel pressure through those injectors while in high boost. Going to get an Aeromotive Stealth pump to replace it.
  7. REDZ
    REDZ Enthusiast
    sounds odd ... have you checked your grounds ?
  8. jblaust
    jblaust Veteran
    Miami, FL
    The video works like it is supposed to for me. It pulls harder than I thought for being automatic. Awesome build!
  9. Litneon
    Cocoa, FL
    94 xtra cab
    Yes, I've been through everything. I got an Aeromotive Stealth for it though. It's going in this weekend.
  10. REDZ
    REDZ Enthusiast
    ok gounds good... reason i asked is because i have seen poor ground and wiring issues cause a similar problem on the dyno recently ... when we got it sorted the guy gained 22 psi of fuel pressure (running 2 pumps)
  11. Litneon
    Cocoa, FL
    94 xtra cab
    My biggest issue is probably that the fuel pump is still on the stock circuit. When I swap pumps, I plan to rewire it to a relay pulled in by the existing pump circuit.
  12. jblaust
    jblaust Veteran
    Miami, FL
    Litneon You know anyone in south florida that can notch my frame? im asking because i dont really know anyone to do the job and your the only one Ive seen on this board in Florida.
  13. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    we need a longer video!!!! lol
    Litneon likes this.
  14. Litneon
    Cocoa, FL
    94 xtra cab
    Where are you located? I know a few shops around here on the Space Coast. Pm me and I'll give you a few contacts.
    Soon. I didn't feel comfortable going any fast than that.... Haha.
  15. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    ok, will be sitting right here patiently (not so patiently) waiting!! haha
  16. REDZ
    REDZ Enthusiast
    lit have u ever seen a coil on plug setup for the 22re?
  17. Litneon
    Cocoa, FL
    94 xtra cab
    I haven't yet. I have a set of LSx coils for mine, but haven't fabbed the bracket for them yet.
  18. REDZ
    REDZ Enthusiast
    i was thinking of some honda k20 coils but i found them to be too long .. did you ever get around to the tubular manifold or do you still have on the log type turbo manifold.
  19. Litneon
    Cocoa, FL
    94 xtra cab
    Still rocking the log manifold. Haven't had time... Sadly.
  20. REDZ
    REDZ Enthusiast
    hey lit i finally decided to do the cop swap
    Litneon likes this.
