And here.... we... go.
Discussion in '1989-1995 Build-Up/Project Threads' started by Litneon, Mar 26, 2010.
  1. Litneon
    Cocoa, FL
    94 xtra cab
    No, sorry. The numbers move when I push the reset, but the odometer and trip don't actually count up. When I push the reset, they just twitch a bit. Because it's already zeroed.
  2. NashMan
    NashMan Toyotaholic
    Vancouver Island, Canada
    94 2wd
    sound liek you have to take it apart
    I have fixed a few once ya have it apart you will see the issue
    but if you have your old one just swap it it's the same as long as it's sr5 cluster
  3. REDZ
    REDZ Enthusiast
    lit how does the welded diff feel in the truck??
  4. Litneon
    Cocoa, FL
    94 xtra cab
    No, my old cluster wasn't an SR5. That's why I'm so excited about this one.
    I had it apart, but everything looks legit.
    The welded diff isn't bad at all. I'm ordering a helical geared LSD, but aside from the tire wear, I wouldn't worry about dailying it the way it is. (I do)....
  5. REDZ
    REDZ Enthusiast
    whats the cost like for the helical geared LSD
  6. Litneon
    Cocoa, FL
    94 xtra cab
    Depends on who you buy it from. $750 from LC.
  7. REDZ
    REDZ Enthusiast
    LOL guess ill be welding mine 750 where im at works out to almost 90k before it being shipped
  8. Litneon
    Cocoa, FL
    94 xtra cab
  9. Litneon
    Cocoa, FL
    94 xtra cab
    So that would only be about 50k shipped to you. :D
  10. coolbet13
    coolbet13 Member
    NC
    would the one for the front not work in our 7.5 rears?
  11. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    If I remember right the trutrac units are front/rear specific so be sure to ask when ordering.
    I don't understand putting $.05 into a 7.5" anyway when the 8" is plentiful, gears are readily available in higher and lower ratios and it is nearly bomb proof in a 2x application.
    Edit: rear 7.5" trutrac is #911A445. Front 7.5" trutrac is #911A342. The 8" front/rear numbers are different also.
  12. Litneon
    Cocoa, FL
    94 xtra cab
    Both of those part numbers are listed as 4wd IFS carriers. The difference is the bearing ID size. Use the right bearings, and either will work. Only the ADD carrier is supposedly not a direct fit from what I can find.
  13. Litneon
    Cocoa, FL
    94 xtra cab
    And sure the 8" makes sense when you don't have to source 5 lug axle shafts and refabricate all of the 4 link brackets.
    The 7.5" is plenty strong for most power applications in a 2wd. I'll let you know if it doesn't work out. :D
  14. White Trash
    Eastern WA
    The shafts come with the housings. I have one in my 89 and one out of an 87 that may end up in my 84 if I ever get around to it. They are found in 4 speed equipped trucks.
    Good luck with the 7.5, link brackets are easy. :lol:
  15. Litneon
    Cocoa, FL
    94 xtra cab
    Thanks, I'll keep that in mind if I ever blow this one up.
    Is it common to destroy one?
  16. White Trash
    Eastern WA
    Start banging gears and catch traction at the wrong time and yes they'll eat the ring gear. The 7.5 case is thin so it allows the pinion to deflect from the ring gear. Even the standard 4 cylinder 8" case is stronger and the V6 case is thicker with more webbing so deflection is mitigated.
  17. Xs5875
    Xs5875 Addict
    Greenville, Ga
    1994 Standard cab 22re 5 spd
    I ruin 3 a year. This N/A 22RE of mine puts about 105 hp out at the flywheel....so...ya know.
  18. first80toyota
    first80toyota Addict
    Pacific Northwest
    '77 Hilux
    This forum needs a like button! Too many awesome comments...
  19. Litneon
    Cocoa, FL
    94 xtra cab
    Wow. Doesn't seem to come up much for being such a serious problem.
    I'm making about 105 to the flywheel, I wonder how long it'll last.
  20. Litneon
    Cocoa, FL
    94 xtra cab
    And my diff is welded....
    It is an auto, but the mods we've done to it make the shift absolutely firm. Even so, I imagine the auto helps significantly.
    I haven't gone through any third members this last year. Come to think of it, I've never had one go bad.
    I'm not arguing against any of what you guys are saying, I'm just not seeing it.
