And here.... we... go.
Discussion in '1989-1995 Build-Up/Project Threads' started by Litneon, Mar 26, 2010.
  1. Minischwendy
    Minischwendy Member
    92 Extended Cab
    Beautiful truck man. Absolutely love what you've done. Also given me a lot to consider on my 92 ext cab.:waytogo:
  2. Litneon
    Cocoa, FL
    94 xtra cab
    Thanks.
    Still have a ways to go, but it's coming together nicely.
    It's picked up so much power now. I love the new addition.
  3. 93_Toy_Mini
    93_Toy_Mini Addict
    Gardnerville, NV
    93 Reg Cab Pickup
    I could of swore I asked you a question but I looked back and I could not find it. Anyway, did you put the renforcement plates on the inside of the rear frame? Where the rear bag brackets are mounted...?
  4. Litneon
    Cocoa, FL
    94 xtra cab
    Yes, I think the rails were boxed in, but I added a plate. I used 1/4" plates and welded them in all the way around. I think in post #13 you can see the plates and welds.
  5. 93_Toy_Mini
    93_Toy_Mini Addict
    Gardnerville, NV
    93 Reg Cab Pickup
    Not sure if I missed this but are you body dropped? You truck looks so low. I have been toying with the notion to do a stock floor body drop and I was thinking about cutting two inches off the bottom of the frame to lay rocker. What do you think about that?
  6. Litneon
    Cocoa, FL
    94 xtra cab
    No, no body drop here. While it would look a bit better, I'm 6"4" and can't spare any head room. And a stock floor body drop would be out of what I'm willing to spend for the extra 1" or so.
    I would stay away from trimming the frame rails because of the stresses involved. You could box it enough to support the weight of the truck, but the extra stresses involved in actual driving would probably lead to the scrap heap.
  7. Litneon
    Cocoa, FL
    94 xtra cab
    Ordered the Turbonetics T3 Super 60 today. With a .48 AR turbine, it should spool a bit quicker than the .63 AR T3/T4 thats on it now.
    After I figure out what I'm doing for (or in leu of...) an intercooler, then it'll be time to schedule some dyno time.
  8. CrazyCody93
    CrazyCody93 Enthusiast
    Gresham OR
    84 Sr5 Xtra cab
    ^ Can't wait to see what you turn out for numbers!
  9. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    I feel you on being tall an in a bodied truck. I'm 6'4" too but cudnt stand not being bodied lost some head room but.gonna take some outta the seat mounts to gain a little back. Truck is super clean man
  10. 93_Toy_Mini
    93_Toy_Mini Addict
    Gardnerville, NV
    93 Reg Cab Pickup
    So let me ask you, with how nice your work is, as far as the finish of your truck's frame, how does it look now? I live were it snows and since mine will be a daily, I am afraid of what that might do to my frame. Do you drive your truck often in the weather or only on fair weather conditions? How does your frame compare now to theses pictures. I can already see me being the only person at the car wash when it is below 32ยบ outside. I am even considering a tilt bed just so I can clean it better.
    P.S. I am almost done with my rear setup. :waytogo:
  11. Litneon
    Cocoa, FL
    94 xtra cab
    My truck is my daily. Can't stress that enough. It has little rock chips and scratches from all the abuse I put it through. Because I used rustoleum, it has faded a bit, but no rust to speak of. I'd say the condition is pretty good overall. I do get under there on occasion and wash it down and check on things.
    It's not the 4 link, but the driveshaft and stuff were painted around the same time as the rest of the rear. The frame rails forward near the transmission are still in factory paint for the most part.
  12. 93_Toy_Mini
    93_Toy_Mini Addict
    Gardnerville, NV
    93 Reg Cab Pickup
    Did you paint your rear suspension set-up assembled or apart? I don't want to get paint on the bushings or any areas where paint will wear off. And I was just wondering what you did.
  13. Litneon
    Cocoa, FL
    94 xtra cab
    Hmm. Think I painted them separately.
  14. NWA STEVE
    NWA STEVE Enthusiast
    missouri
    1987 toyota xtra cab longbed
    catching up on youre build thread bro nice work.
  15. Adrian2013Ibarra
    Adrian2013Ibarra Enthusiast
    94 Toyota Pickup Ex Cab
    Are you planning to sell the old turbo afterwards?
  16. NashMan
    NashMan Toyotaholic
    Vancouver Island, Canada
    94 2wd
    I could give ya an idea or 2 some of the ways don't even need one
  17. Litneon
    Cocoa, FL
    94 xtra cab
    I probably could sell the old turbo. It's a Chinese made eBay model. I can tell you all I know about it if you are interested.
    NashMan, I'm listening...
  18. NashMan
    NashMan Toyotaholic
    94 2wd
    Well air to water unite form pwr saves space Liquid To Air Intercoolers | PWR Performance Products or Run a water injection or 50/50 mix meth/water injection
    both are rather stealth and what not plus you don't have to find away to stuff a inter cooler up front
    I was just going to run 50/50 mix and run 87 ocatain for my truck and still be boosted and still run reg gas you can still do this running just water too but I would run 89 ocatain with that setup
  19. Litneon
    Cocoa, FL
    94 xtra cab
    Yeah, I'm looking at the Cooling Mist stage one kit. I'd rather run an air to air if I can figure out how to do it. I'm thinking I may have to build a custom intercooler.
    As of right now, I'm running a little over 10 pounds of boost. It starts building boost at 2300 rpm and is at full boost before 3000. Intake air temps are still OK, but I want to go more boost.... Finally decided that my goal now is 275 whp.
  20. NashMan
    NashMan Toyotaholic
    94 2wd
    i would a run snow or aem my self
    cheap easy runs on reg gas saves ya money
    and if you add a iner cooler it will add lag
