And here.... we... go.
Discussion in '1989-1995 Build-Up/Project Threads' started by Litneon, Mar 26, 2010.
  1. mrgreg
    mrgreg Newbie
    wales uk (over the pond)
    91 2 door surf
    Hi, awsome build just read through the lot :) Yotaforce made a comment about engine swap and mentioned the 20v age out of a mr2 what gearbox would you mount it to ???? only ask as Im thinking off doing one myself :confused: cheers Greg
  2. planemos
    planemos Toyotaholic
    British Columbia
    That would be the 4 AG engine and I think the AE86 Corolla/Trueno had that same engine. Only it was mounted in the front of the car. Where as the MR2 had it mounted in back. So I would imagine you would look for one of those transmissions.
  3. Yotaforce
    Yotaforce Enthusiast
    Sacramento, CA
    94 xcab
    My brother is the MR2 expert, but i do believe when they do 20v swaps in truenos, they keep the transmission. Not 100% sure though. :shrug:
    You got pics of that Surf greg? i love those things.
    (sorry for thread jacking)
  4. IronNam
    You'd have to get the 4A-GE and rwd transmission from the AE85/6's. Finding the actual 4A-GE is pretty tough.
  5. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
    looks great david!
    i wish i knew how to make stuff outta wood and fiberglass. i tried and failed pretty bad lol
  6. Litneon
    Cocoa, FL
    94 xtra cab
    So, started the bed floor project...
    Got the bed for $50 from the local pull and pick... Pretty rough.
  7. Litneon
    Cocoa, FL
    94 xtra cab
    Wedged into place, that was a trick. I decided to leave parts of the existing floor and mounts so as to minimize the possibilities of causing too much damage to the sub frame. Also, by doing this, I didn't have to build new mounts for the bed.
    Everything was welded and seam sealed.
  8. Litneon
    Cocoa, FL
    94 xtra cab
    Got dark again. Funny how that happens. You can kinda see the filler plate for the rear of the bed.
    After the first coat of Duplicolor Bed Armor.
  9. Litneon
    Cocoa, FL
    94 xtra cab
    And finally, reassembled. I was so ready to have the bed back on the truck. Took about two weeks to get done. I'd like to fab up some inner fenders for it, but we'll see.
  10. Da_Roach
    Da_Roach Toyotaholic
    NOVA
    (1) 92 RN80 (1) 2002 RZN150
    That turned out great. I like how to kept a "factory" floor and it looks stock. Would have been cool if on the filler plate you made it look like the floor. Nice work. Can't wait to see more interior work done.
  11. Litneon
    Cocoa, FL
    94 xtra cab
    Thanks, yeah I had thought about that. The only problem with the ribs is that they transition into a flat surface at the rear, so then to keep with that look, the smooth sheet worked out better. My buddy wants me to stick a pair of weatherproof mids in that plate though (probably won't go that route...). :)
  12. tyme_fo_play
    tyme_fo_play Addict
    94 BLOCK HAWAII
    MY PRIDE MY JOY MY TOY!
    Nice job on the raised floor bed.
  13. Yotaforce
    Sacramento, CA
    94 xcab
    The bed looks great man. Any updates on the stereo?
  14. Litneon
    Cocoa, FL
    94 xtra cab
    Ha! Yeah, that got put on hold for the bed. The new door pods are almost done, just need to finish sand them and get them to paint. I also need to build my center console, haven't started that.
  15. Dgerfan55
    Dgerfan55 Grand Toyotaholic
    lake elsinore CA
    94 pickup
    WOW...... WOWOOW, nice job. I really like it. Way better then a big hole in the bed.
  16. Litneon
    Cocoa, FL
    94 xtra cab
  17. Litneon
    Cocoa, FL
    94 xtra cab
  18. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    damn clean as hell! looks great in the truck, i like how it jumps out at you with all the grey in there! Very nice work!
  19. Litneon
    Cocoa, FL
    94 xtra cab
    So, my buddy Charlie painted these for me, and helped straighten out a few bits of the body work that I couldn't figure out. I built an LED circuit for the gauges and changed the color to red for night vision purposes. Wow, too much to comment on right now. Let me know if you have questions...
  20. tyme_fo_play
    tyme_fo_play Addict
    94 BLOCK HAWAII
