After the Webber conversion.....
Discussion in 'Maintenance/Repair' started by l2ewind, Jul 25, 2018.
  1. l2ewind
    l2ewind Member
    Fort Collins Co
    1977 Hilux
    What's going on fellow Toyomini subs. I just recently finished the webber install, and emissions delete on my 77 pickup. I have a few questions on a couple loose strings that I can see.
    There is an air line that runs around and behind the motor, ( I believe it was from the smog pump) between the firewall and motor. Can I cap this, or remove it entirely?
    Also, these are few extras that I didin't remove in fear of something not working correctly. I believe one is the relay for the fuel pump? The other connects to the charcoal canister (top one). Can I remove all of these without any issues?
    Finally, I currently have the inlet on the weber air cleaner capped of as I was told that the pcv hose should be connected here. That doesn't make sense to me as you have a chance of oil getting into the cleaner and gumming everything up. Does it make more sense to T into the vacuum line currently going from the brake booster to the intake?
    Much thanks for your help and input!
    JC
  2. l2ewind
    l2ewind Member
    Fort Collins Co
    1977 Hilux
    Sorry guys, I just realized my links were dead... my apologies. IMG_20180725_161944.jpg IMG_20180725_162003.jpg IMG_20180725_162003.jpg
    Erwin Merida likes this.
  3. Perkolator
    Perkolator Toyotaholic
    Placer County
    1975 Hilux
    Being located in CA and removing your emissions stuff -- how are you planning to pass SMOG?
  4. l2ewind
    l2ewind Member
    Fort Collins Co
    1977 Hilux
    lol, moving out of California on the 9th!!! no more smog requirements!!!
  5. Henry
    Henry Enthusiast
    Washington State
    I don't live in CA, but would a 77 still need to pass SMOG?
  6. Tuhd The Troll
    Tuhd The Troll Veteran
    Houston, TX
    1982 SR5
    Visual inspection would likely be where you fail.
    Technically even in Texas, where my truck doesn't even remotely have to be smogged ('82), if the inspector is a dick, he can fail my vehicle because the engine vacuum lines don't match the sticker under the hood. Last guy told me to just remove the sticker, or make a new one that follows what's there.
  7. Perkolator
    Placer County
    1975 Hilux
    Yes. Pre-smog is 1975 and older, 1976+ all require smog testing.
  8. Henry
    Henry Enthusiast
    Washington State
    Did you cap off that airline that runs behind the engine? Is this the line that connects to the exhaust manifold? I just purchased a set of pacesetter headers for my 20r and I see it has he connects for this line. I'm debating about welding them shut since I'm deleting all of the emissions stuff at the same time I'm installing the weber.
