93 toyota pickup spindle lock nut washer and pin
Discussion in 'Suspension/Chassis' started by HUNTER HARRELL, Jun 3, 2020.
  1. HUNTER HARRELL
    HUNTER HARRELL Newbie
    Where can I get a new set of lock nut washer and pin for my 93 toyota pickup. Had to replace my passenger side spindle because wheel bearing failed and ruined my original set thanks guys the nut is a 30mm thanks
  2. Perkolator
    Perkolator Toyotaholic
    Placer County
    1975 Hilux
    common parts like this should be available on the shelf from most parts stores
  3. HUNTER HARRELL
    I've looked auto zone advanced etc and cant seem to find. Only thing they have is for the 4 wheel drive models
  4. sirdeuce
    sirdeuce Veteran
    '86 4Runner and '89 2WD
    Try posting in the "want to buy" section of this forum.
  5. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    Find out the pitch and order online. It's called a castle nut if I remember right. You can probably find a parts diagram online too. It will tell you the part number to find the exact one.
  6. HUNTER HARRELL
    Ok thanks appreciate it!
