'93 Hilux Build in Miami from head on collision !
Discussion in '1989-1995 Build-Up/Project Threads' started by The Jewish Guy, Apr 19, 2013.
  1. The Jewish Guy
    The Jewish Guy Veteran
    Here is the wiring for the cooling fan... it is wired right... fan stays on after i turn off the ignition... I have to work on that to make sure that it turns off with an alternate switch or something because i don't want to drain my new battery.
    Here is a closer up pic:
    This is where the negative switch was installed... since it was a bit long i had to get a 3/8" thread elbow from Lowes ( $3.99) to make it work with a little JB Weld
    I also used some sealant that i got from ACE hardware that is especially formulated to work in fuel systems...I used this stuff on my HP VW Motor for my '67 Beetle.
    Here is the VW motor:
    I used the ACE sealant on the full flow system of my vw motor:
    See the sparkles on my Hilux ?
    Tomorrow I will post more updated pics and an itemized list of all the parts and components that I have purchased and the places that i bought them.
  2. 93_Toy_Mini
    93_Toy_Mini Addict
    Gardnerville, NV
    93 Reg Cab Pickup
    Nothing new on EBay is JDM and I am willing to bet that the ones you bought here are not JDM either unless that guy bought them from a Japanese supplier directly from Japan which came off of a used Hilux. JDM = Japanese Direct Market. Yours are more likely USDM because it's not worth importing mirrors from Japan.
  3. The Jewish Guy
    We have had torrential rains and downpours that the sun has not come out long enough to take some decent pictures... here are some that it took at night...
    See the sparkle
  4. Blitz
    Blitz Enthusiast
    Georgia!!
    It's not a Toyota
    Clean as a whistle
  5. NickMiller
    NickMiller Newbie
    I LOVE this truck! Subbed ;)
  6. Da_Roach
    Da_Roach Toyotaholic
    NOVA
    (1) 92 RN80 (1) 2002 RZN150
    truck looks super clean. Are you gonna paint the frame black again?
  7. The Jewish Guy
    Have to find a lift so I can paint the frame black
  8. Blitz
    Blitz Enthusiast
    Georgia!!
    It's not a Toyota
    You could always just remove the bed and front clip. You'd only have the part where the cab remains left.
  9. The Jewish Guy
    What would i want to that ?
    Defeats the purpose of having a truck
  10. icpurplepplalot
    icpurplepplalot Member
    Baton Rouge
    94 Base
    He was talking about doing that to paint the frame.
  11. Blitz
    Blitz Enthusiast
    Georgia!!
    It's not a Toyota
    Yep. What he said.
  12. The Jewish Guy
    Installing a Kenwood radio... not an easy task since the factory cutout is smaller dimensions than the radio actually is. I used a rotary tool stone to grind away but i think i took a little too much... if i hadnt then the slip on radio frame would fit snug but oh well I have reached the point of no return .. the other option is to buy another front dash piece which is what i will probably end up doing so i can get it right the second time... in the meantime i will be using the coin/cup holder panel underneath to hold the weight of the radio.... this was a suggestion that a forum member named Roni "AssYriaNrocKer" made. Unfortunately the coin/cup holder piece doesn't quite fit right on a Mini... it fits better on a 4Runner. Again i reached the point of no return so i have to use it.
    You can see the gap on here:
    Well here is the finished product... if i had known that the fitment would not be flush on the mini i would not have done it... you live and learn
  13. The Jewish Guy
    I see where i made a mistake !!
    I should have removed the dash face panel first and have it installed from the inside... like this it would sit flush behind the dash face panel and there wouldn't be a need to grind away at the dash panel cutout... i feel really dumb now for not having looked at your photo a lot closer... i guess i will need a replacement panel.
    Below is taken from Roni's "AssYriaNrocKer" 94 Single Cab thread:
    Here is a shot of how the Ford cup holder fit in the 4runner. It takes a little fab-ra-ma-cation but nothing complicated. Fits nice and works well.
  14. The Jewish Guy
    Here is the grand total of all that I spent on this build:
    (Keep in mind that most of the prices are Wholesale prices from the business relationships i have had for several years.)
    DATE--- COMPANY--- DESCRIPTION ---- PRICE $
    3/18/2013 JONAS 1993 TOYOTA HILUX 22RE $ 400
    3/22/2013 KEYSTONE Hood 74.60
    3/21/2013 KEYSTONE Fender - LH 28.48
    3/21/2013 KEYSTONE Fender - RH 28.48
    3/21/2013 KEYSTONE Front Bumper - Chrome 56.38
    21-Mar KEYSTONE Valance Front 15.00
    21-Mar KEYSTONE Grille Front Chrome 28.64
    22-Mar Ebay Right Side Window Glass OEM 32.85
    25-Mar Ebay Clear Rear Red Tail Light 24.51
    26-Mar EBAY Clear Front Turn Signals $27.81
    26-Mar EBAY Clear Front Corner Chrome Lenses 49.99
    28-Mar STREETSIDE AUTO Westin Diamondsetp Rear Bumper 212.51
    28-Mar STREETSIDE AUTO Westing Bumper Install Kit 53.01
    2-Apr GENERAL AUTO GLASS Windshield 150.01
    2-Apr SUNBELT Radiator - New 53.01
    2-Apr SUNBELT Radiator Cap 5.01
    2-Apr SUNBELT AC Drier 7.01
    2-Apr INSIGNIA Radiator Support 54.01
    2-Apr EBAY New Bumper Bracket -LH 11.19
    EBAY New Bumper Bracket -RH 11.19
    3-Apr Worldpac BOSCH Water Pump 22.63
    Worldpac BANDO - Drive Belt AC 4.81
    Worldpac BANDO - Drive Belt Alt 6.09
    8-Apr West Kendall Toyota Drier Tube Aluminum 40.63
    8-Apr West Kendall Toyota Rad Bolt & Washer 3.58
    12-Apr Sunbelt AC Condenser 72.01
    19-Apr West Kendall Toyota Rubber Hood Stops 2 pcs 5.30
    20-Apr Advance Auto Parts Black Battery Cable 11.79
    20-Apr Advance Auto Parts Red Battery Cable 11.79
    22-Apr Worldpac Valve Cover Gasket 12.43
    Worldpac Timing Cover gasket 1.18
    Worldpac Timing Gear Kit Complete 60.57
    Worldpac Water Pump Gasket 1.55
    22-Apr WNC Auto Parts -Ebay Distributor - Used 75.01
    22-Apr Roni Younan JDM Mirrors - Used 25.01
    23-Apr Worldpac Oil Pan Gasket 4.31
    West Kendall Toyota 22RE Engine Plate Name 2.12
    3-May West Kendall Toyota Emblem "Toyota" Grille 19.35
    MOP Headlight Buckets Pr. 40.01
    MOP Radiator Overflow Tank 15
    MOP Windshield Washer Tank 15.01
    EBAY Stant Oil filler cap 4.31
    Ebay Fan Relay with Thermostat 27.76
    4-May Advance Auto Parts Spectre Air Intake 90 degree Chrome 11.99
    Advance Auto Parts Mobil One 15W50 Synthetic Oil w/ Filter 33.49
    6-Apr Advance Auto Parts Spectre Air Intake Silicone Joiners 12.49
    6-May Ebay 12mm Oil Catch Breather Cone Small 4.04
    14-May Advance Auto Parts NGK Spark Plugs 9.56
    17-May Ebay Chrome Exterior Door Handles 20.01
    17-May West Kendall Toyota Headlamp Adjusting Screw 5.91
    17-May Ebay Chrome Tailgate Latch 12.15
    17-May Ebay Blue Air Intake Filter 17.9
    21-May The Parts House Headlight Adjustment Screw 4.87
    The Parts House Headlight 3 prong Socket 1.65
    4-Jun Worldpac YEC Distributor Cap 10.93
    Worldpac YEC Distributor Rotor 4.38
    17-May U-Pick Auto Salvage Pioneer 3 Way speaker 20.00
    U-Pick Auto Salvage Coin/Cup Holder - 92 Ford Taurus 7.49
    23-May Lowe's 3/8" Brass Elbow fittings 6.42
    Lowe's 3/8" Brass Elbow fittings 2.83
    30-May Almesiga Tire Nexen 205/50/15 New Tires 100.00
    3-Jun The Parts House Headlight 3 prong Socket 1.77
    4-Jun Ricky Evans Dash Radio Face Plate 11.01
    5-Jun Roni Younan Steering Column Cover - Grey 26.01
    PARTS TOTAL $ 2,136.76
    DATE--- COMPANY--- DESCRIPTION of LABOR ---- PRICE $
    8-May Juan Carlos Crespo Labor on Timing Chain Replacement 200.01
    20-May Angel Auto Body Body Work & Paint Pearl White w Blue Pearl 1,540.01
    23-May Jonas Fan Relay Labor 60.01
    31-May Frio Car Air Conditioning Recharge 80.01
    LABOR TOTAL $ 1,880.04
    GRAND TOTAL COMBINED $ 4016.31
  15. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Well worth it man .. Took a neglected and wrecked up truck and turned it around into a head turner in a short amount of time . Sure it will give you years of reliable transportation
  16. The Jewish Guy
    Here are some pics I took on Sunday with my Hilux
  17. The Jewish Guy
    I had to redo the wiring job for my cooling fan because it was draining my battery
    So i got a professional that is truly a pro at this to rewire it.. the trigger comes from the actual ignition under the steering column because using the ignition coil personality plug can cause the personality plug to burn from the hot current running from the fan.. so here is the before and after pics:
    BEFORE
    AFTER
  18. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    damn man nice truck/transformation.
    nice old school centerlines, sabres i think they were called...they sit just rite, wish i could find a pair around just like those!!
    nice truck man!!
  19. The Jewish Guy
  20. The Jewish Guy
    I got a steering column cover from Roni... just need the other interior pieces and i will be done.
