90 SBC 350 Drift Truck
Discussion in '1989-1995 Build-Up/Project Threads' started by Blakesommers77, May 1, 2016.
  1. Blakesommers77
    Blakesommers77 Member
    Also, with my Radiator being lower than my block I was having some issues with Cooling. I installed a Petcock type Valve on the Water Neck where the 1/2 bolt is above. This solved the cooling issues we were having. 4.3 S10 Radiator and an electric fan seems to be doing the trick for now.
  2. Blakesommers77
    So I got an awesome deal on another turbo 350 that has had some major work done to it. All the goodies and a 2800 Stall Converter.
    We had to cut the cross member out to remove/install the new tranny.
    Made brackets for the cross member out of 1/4 inch steel strip. (Grade 8 Bolts, nuts and washers)
    Borrowed a tranny jack from a friend which made the install go pretty easy. Took about 5 hours to get the Tranny bolted back up to the engine.
    Cross Member bolted back in.
    Got pissed off while struggling to drill out the steel plates so I took an impulsive trip to Home Depot.
    My dumb as* did not think of the difference in shaft lengths with the Turbo 350 so now my Driveline does not fit. Dropping it off again tonight to hopefully have it ready to install by Friday/Saturday. This is really all that's needed to get it driving again.
    Hoping to get the front of the truck all buttoned up this weekend and then it's on to installing the Roll Cage, Harness bar and door bars.
    Moved my truck to another friends house to give the other guy some space for other projects :)
    Lots of late nights this week but pretty happy that we were able to knock this tranny swap out. I was a little nervous because it was my first time ever touching a tranny and this is not an easy intro.
    -Blake
  3. Blakesommers77
    Originally I was really unsure of how the heck my Valance was going to fit on with the added radiator and tranny cooler. Few minutes of trimming on it looks like it may actually work out. Sadly the front of my truck looks a little haggard from when it was stolen and crashed.
  4. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
    The rodeo/passport valance might cover all that...
  5. Blakesommers77
    Got to take it for a drive today. It straight hauls ass. New transmission feels really good. Only got into it about half throttle. This thing is insanely loud with open headers. Didn't wanna draw too much attention ;)
    video on my Instagram @ruinedyota
    https://www.instagram.com/p/BH7dv8zhVXo/?taken-by=ruinedyota
    So much more to do but the big stuff is out of the way.
    Keep this thread alive, there is some fun stuff happening soon.
    Full Roll Cage/Harness bar and Door Bar install (Video Series)
    Bride Seats
    Hydro Ebrake
    Custom Cluster inside the factory housing.
    Buddy and I have decided to start filming this semi controlled chaos that is us building cars/bikes so stay tuned on that.
    He has a Saab 92-x Aero (Saabaru) 2001 S10 that we are 350 swapping soon, and an old VW Cabriolet
    I have a CB500 Cafe bike ill be starting on soon to finish/finish it right.
    If any of this sounds entertaining to watch you should let me know.
    -Blake
    jblaust and YOguyDA like this.
  6. Blakesommers77
    Oh and Coil-Overs
    That's a big one that I forgot to include. :)
    Blake
  7. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
    All of that sounds entertaining!
    I'm mainly interested in the custom gauge cluster and the cb500, lol.
  8. Blakesommers77
    I'm having some fuel issues that have me stumped at the moment.
    Both of these lines were bent out of the way and remounted higher on the fender from their old spot down lower. Reason being is the fumes started a fire once........
    Anyway, I was under the impression that there was a feed, return and vent line? I am only running the feed right now and the return off the fuel pump is blocked off.
    Just saw some fuel splash out of one of them while driving, how do I prevent this?
  9. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    As you know the feed is down on the frame. The return line goes into a hard line that returns to the bottom on the tank and the vent just has a short stub into the tank to let vapors escape.
    Easy way to figure it out is to take the gas cap off and have someone blow air into a line and listen for bubbles. If you don't here bubbles then you found the vent so block the return off and you'll be fine.
    Blakesommers77 likes this.
  10. Blakesommers77
    Thanks for the info man, Ill do that test and get the return blocked off. Thanks!
    Going to try and get the truck to an exhaust shop this week so I can start driving it every day.
  11. Blakesommers77
    @White Trash That worked like a charm. Thanks for the pointer! No more gas leaks :)
    I know this is kind of a boring part of the build but I promise it will get more eventful soon. Im just waiting on exhaust to get done on this thing.
    Should be starting on the roll cage / bucket seat install soon.
    Stay tuned :)
  12. Blakesommers77
    Started on the cage last night, all the bars are welded and the base plates are tacked to the floor. It will be tied into the frame soon. Seats and harness bar will probably go in tonight.
    Still need to make door bars as well.
    For those curious this is the cage I used. http://www.4xinnovations.com/89-95-Reg-Cab-Pickup-Internal-Roll-Cage_p_13.html
    I am having to shorten the middle bar and re-notch it. The bar by your head is a little too close for the middle bar to fit into place. Ill post more pics tonight/tomorrow.
    -Blake
  13. Blakesommers77
    Seats, harnesses and harness bar are installed.
    LAYNLOW likes this.
  14. Blakesommers77
    Transmission leaks have been an issue since the start of this build. Replaced the old factory metal lines with some fuel line. Seems to have solved the tranny fluid issue. Now to try and fix my oil leak from the pan.
  15. Blakesommers77
    Took the truck out for about 5 hours on Saturday night and it ran like a dream. S10 has a 350 in it, 280 has an LS1 with a t56 and the Corrado is chipped and cammed.
    I decided an old parking lot was a good place to destroy some tires. Truck slides amazing, actually felt very predictable. Its even better at alerting the cops of my location. One cop loved my build, the other looked annoyed at the young cop who just wanted to talk about the project haha. No ticket :)
    Next up is to weld the diff.
    Then track time
  16. Orlando Muniz
    Orlando Muniz Veteran
    Pflugerville, TX was Sac Town, CA
    89 Toyota Pickup
    Damn looks good man, congrats man! What other plan do you have?
  17. Blakesommers77
    Thanks man.
    Boost (blow through carb setup)
    4 Link the rear
    Coilovers front and back.
    Tubed front end
    Mount Radiator in the Bed
    Fuel Cell
    T56 (6 speed)
    Paint/Fender Flares
    Just picked up some new wheels yesterday, so I should have those on this week. 15x8 Soft 8's (3/3/4 BS)
    Heads are probably getting changed this week to the Vortec Heads.
    Hoping to hit the track in the next two weeks and see what breaks.
    Lots to be done :)
  18. Blakesommers77
    Picked up some new wheels, rear sits flush with the fender. I may run spacers in the rear. 15x8 Trail Masters. 3 3/4 BS.
    twizted1 likes this.
  19. Blakesommers77
    Got a nice pic yesterday with the new wheels.
    Will post some more soon.
    Check the link or @ruinedyota on instagram
    jblaust likes this.
  20. yotarip
    yotarip Veteran
    Nice! love the stance.
