86 toyota slow build, from rags to bags..
Discussion in '1984-1988 Build-Up/Project Threads' started by Barret S, Dec 7, 2009.
  1. GrantH
    GrantH Addict
    Hattiesburg, MS
    will you see if he would be willing to get rid of it?
  2. Barret S
    Barret S Veteran
    Ellisville, MS
    86 Standard cab 2wd
    i'm sure he would be, i pm'd you my cell hit me up. Although... the floor between the well's is cut too cause the truck laid out.
  3. Barret S
    Barret S Veteran
    Ellisville, MS
    86 Standard cab 2wd
    ok i got the bed off, now time to start measuring to fit a tank, remove drive shaft and get ready to find an 8.8 rear end, c notch the frame, and all that good stuff. Sorry for the fuzzy photos
    88darthyota likes this.
  4. 22R_All_Motor!
    22R_All_Motor! Addict
    Houstone
    84 pickup
    i wanna see pics of your gsr!!... im dieng to see it.. lolz....
  5. Barret S
    Barret S Veteran
    Ellisville, MS
    86 Standard cab 2wd
    dying to see it? ha well ok here it is.
  6. Barret S
    Barret S Veteran
    Ellisville, MS
    86 Standard cab 2wd
    These pics are for Grant.. Let me know if you want em'
  7. Dgerfan55
    Dgerfan55 Grand Toyotaholic
    lake elsinore CA
    94 pickup
    Nice build and welcome to TM. Keep us posted and good luck.
  8. GrantH
    GrantH Addict
    Hattiesburg, MS
    i definitely want the exhaust and driver fender but the fender will have to wait. i HAVE to figure out my exhaust problem before I go about doing much else.
  9. Barret S
    Barret S Veteran
    Ellisville, MS
    86 Standard cab 2wd
    ok well if you want to get the exhaust part from me, either this evening or tomorrow will be good, i will be working on the truck pulling the 22r this evening and tomorrow i will be out on your end of town picking up the new wheels.
  10. Barret S
    Barret S Veteran
    Ellisville, MS
    86 Standard cab 2wd
    Ok so i took the fenders off as well as the hood to get ready for my engine removal.
    Also i finally got possesion of the 19" wheels and only two have tires but i went ahead and mounted them up on the rear. When weight is put on the rear end the tires will actually touch the frame, but because i'm going with the wider ford 8.8 rear end, that clearance will be taken care of, but here are a few pics from today's progress.
  11. Dgerfan55
    lake elsinore CA
    94 pickup
    Looking good man keep it up.
  12. Barret S
    Barret S Veteran
    Ellisville, MS
    86 Standard cab 2wd
    So far i have been keeping a log of money spent on this project, i'm at $651 dollars.
  13. GrantH
    GrantH Addict
    Hattiesburg, MS
    aka: wheels. right? what else have you got for it?
  14. Barret S
    Barret S Veteran
    Ellisville, MS
    86 Standard cab 2wd
    all i have purchased so far was the wheels, the 4x4 bed, the 4x4 fenders, and some odd and end, da sandpaper pads, primer, etc.
  15. GrantH
    GrantH Addict
    Hattiesburg, MS
    oh ya...i forgot about the bed and all haha. you found a deal on those wheels if your only that much in. i wouldnt mind a diff set of 16's for a while. something shiny.
  16. Barret S
    Barret S Veteran
    Ellisville, MS
    86 Standard cab 2wd
    yea 200 for the wheels, they need tires and to be reconditioned a little bit. Try finding you some nice cobra r wheels, i think they came in 17's and 18's. not sure.
  17. Barret S
    Barret S Veteran
    Ellisville, MS
    86 Standard cab 2wd
    Ok didn't get too much done this evening, just enough time to remove all the wiring to clear the fender wells and get them ready to cut out next week. Got a little cancer where the battery tray was. Also removed the wipers, motor and assembly, and cowl to get it ready to go get shaved.
  18. GrantH
    GrantH Addict
    Hattiesburg, MS
    wish you would have kept your AC stuff mounted haha. i'm thinkin about trying to get mine back in. the guy who did my work said the heater didnt fit, but i'd like my AC back.
  19. Barret S
    Barret S Veteran
    Ellisville, MS
    86 Standard cab 2wd
    i kept all of the a/c and heater equiptment. I will have a/c and heat in the truck, the only faulty thing i have is the a/c compressor which is locked up. I will not need it though since i will have the350 based engine and a compressor for that application.
  20. GrantH
    GrantH Addict
    Hattiesburg, MS
    i meant so i could see if i still had everything. i think i have everything still though.
