84-88 Pickup and 4Runner SR5 Gauge Cluster swap write up by SD Yota
Discussion in 'Interior/Electronics' started by SD YOTA, Jan 13, 2009.
  1. CatLes
    CatLes Newbie
    Washington State
    88 Toyota Truck
    Thanks for the great pictured info but I wonder where do I hook up the wires for the voltage gauge to work?
  2. GrantH
    GrantH Addict
    Hattiesburg, MS
    Just so it's known, and i'm not sure if it's been mentioned, but you do not have to repin the harness. There is a nut on the back side you can simply put a ring terminal and wire on and secure them down.
  3. guahan671
    guahan671 Enthusiast
    NY
    86 Toyota (sold)
    GREAT GREAT GREAT write-up!!! now all i need to get is a sr5 cluster. i dont like adding a tach, looks kinda messy. thanx alot SD Yota! (but, still waiting for solutions mentioned...) thanx again!
  4. wheels
    wheels Newbie
    New Zealand
    88 YN57 (2wd single cab 3y)
    Just to answer my own question from a while back. :runaway: the fuel gauge works fine it just keeps showing the tank level as it was before the key was turned off. And in answer to the other question,The voltage display must work from the exsiting wiring as you don't have to run a wire for it. :waytogo:
  5. Toy88yota
    Toy88yota Member
    88 2wd
    I believe I just bought a cluster out of an 82-83. Does anyone know if it will work in my 88?
  6. Gecko83
    Gecko83 Newbie
    Seattle, WA
    82 SR5, 91 SR5
    SD Yota,
    Can this be done to a 91 as well ....
    I would love a tach and the other gauges would be much nicer...
    thanks for any response... from anyone in this regard..
  7. DannyBoy
    DannyBoy Enthusiast
    Tacoma, WA
    91 xcab
    yup. have em in my 91 xcab 22re 5 speed.
  8. flacostaco
    flacostaco Toyotaholic
    Corona Southern Cali
    87 pickup
  9. AGUILAR3
    AGUILAR3 Veteran
    SoCal (626)
    So as long as its off of a 4cy and the speedo cable matches my own (cable/electric), any year gauge cluster should work on my 92? What if its a v6? and is there a visual difference between a 4 and v6 cluster?
  10. tacobo670
    tacobo670 Addict
    Las Vegas
    94 Base
    .... same here. looking to pick up a cluster out of a 95 4Runner --sr5 v6. electronic speedo (as is in my 94 -base 22re) will the cluster work? or will i have to mess with the wiring to get it to match with 4cyl?
  11. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    awsome write up, it helped a ton :waytogo:
    for me on a carb'd 87 i changed the oil sender and ran a tach wire off the factory plug on the coil, otherwise it was plug and play.
    i connected my tach like this, will be replacing the connectors with factory stuff when i find it.
  12. igoingtellmymom12
    igoingtellmymom12 Member
    88 pickup
    I was wondering if the sr5 cluster and the turbo sr5 cluster would be the same???? Like wiring because I installed a turbo cluster thinking it would be the same....
    I hooked up the tach wire... Works perfectly... Hooked up the oil pressure switch.... Works...
    But my fuel gauge doesn't.... ???? I'm kinda scratching my head why it doesn't work... I have gas in my tank....
    Any suggestions????
  13. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    it could be a bad gauge. its not the digital one is it??
  14. igoingtellmymom12
    88 pickup
    No it's like the sr5 cluster with the turbo light right underneath the rpm tach
  15. SD YOTA
    oh ok... umm, if your stock gauge was working before on your old cluster, i would say its the gauge on the new cluster is broke... you can check the connection on it and make sure its making good contact, if not, you will need to take it apart and replace it or repair the old one.
  16. igoingtellmymom12
    88 pickup
    Just found out that the sr5 turbo cluster is different from the sr5 cluster... The cluster works fine it's just that the fuel sender is different from a turbo truck to a regular truck....
  17. SD YOTA
    ah man... that sucks...
  18. Elhuaraches
    Elhuaraches Member
    San Bernardino, Ca
    1984 Toyota Hilux 4x4
    Hopefully someone might have an awnser. well i did my swap on my 84 Rn60 and everything seems to work except for my 4WD light. it is on the right pin and it does receive signal ect. i even swapped the light bulb underneath it and still doesnt work.
  19. rusty904
    rusty904 Newbie
    Reviving a very old thread. This seems to be the best write up I can find for this but is there anyway to get the pictures restored?
    Erwin Merida likes this.
  20. Erwin Merida
    Erwin Merida Toyotaholic
    Long Beach, California
    LEXXXI - angry '93 ShortBed
    That would be helpful..
