82 A/C Compressor
Discussion in 'Maintenance/Repair' started by Ashton, Jul 19, 2019.
  1. Ashton
    Ashton Newbie
    Jacksonville, Fl
    1982 Toyota Pickup Dlx LB
    So I did a retro fit on the ordinal A/C compressor worked great for a week then the compressor started leaking. My problem now is I can’t find the right A/C compressor was wondering if anyone had a link with someone who has them in stock
  2. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Just just got a replacement for my 88, google search for your truck , also you have to know what came in it new so fits the brackets if more than one .
    Another very important this is doing all the correct steps with the install,if was R12 ,dump any oil in the unit,flsah with the correct product & add the Pag oil in the correct amount. Than vacuum the system, check that hold pressure ,than charge the system. You can find the videos of how do all on line.Must change the dyer also!
    Mine is not holding pressure then after changing all the o-rings ,which for 134A are green in color. Have a tool coming to help fine the leak.
