79-95 upper arms
Discussion in 'Suspension/Chassis' started by DHPmike, May 31, 2009.
  1. IronNam
    mine survived plenty of curbs. Toyota BJ +1
  2. DHPmike
    DHPmike Member
    Breaking a balljoint is not an easy thing to do on a properly designed suspension. If you knew all the facts in each case of ones breaking you would probably find that they were getting binded up or topping out or bottombing out. Balljoints dont just break for no reason.
    I like the S-10 balljoints because they have a good size, they fit the Toyota spindle and done have a big plate where they bolt on. They use the small cup so they are good for fabricating parts.
  3. Twisted Minis
    Twisted Minis Addict
    Poor Cal
    1980 Toyota
    Ya I don't know the situation of the ones I fixed, I didn't receive much of the balljoint.
    Why not just use the screw in balljoints? Then you don't have to deal with the bolt pattern at all? And they are really cheap, at least the uppers are.
  4. Evolmotorsports
    Evolmotorsports Veteran
    SCV cali
    1987 RN50 Hilux
    Yeah I've never heard of the srew in type ever breaking, the s10 bj's I saw break were under heavy loads coming down from the air, they were being limited though, I was under the impression that having a larger heavier wheel such as a 20" being pushed hard in to a corner would be the same as far as the leverage factor.when they broke the cup had sheered from the flange.
  5. DHPmike
    DHPmike Member
    I dont know of a screw in that fits the Toyota spindle lower hole. Unless Ive just missed it somehow Ive been all over the screw in balljoints. I love using them on everything if I can.
  6. DHPmike
    DHPmike Member
    I now have these available and Im gonna build several sets. I owe at least one set already. let me know if you need some.
  7. DHPmike
    DHPmike Member
    Ok the lowers pic is here. I swapped it out on the website with the old one of the lowers uncompleted. Here it is just in case you guys missed it.
    let me know what you think.
  8. IronNam
    i'll keep these in mind if i ever need to upgrade....
    you would understand after seeing the hydrant killer lol
  9. thundering02
    thundering02 Addict
    Fenton 63026
    Do these drop ride hieght like the DJM's? also no provision for the torsion bar ... so bag only set ups?
  10. DHPmike
    DHPmike Member
    Yes for bags, cans or juice only. No torsion bar setups. They drop the ride height to whatever you want it to be. Theres no comparison since theres no way to mount it to the original spring.
  11. smctoy
    smctoy Toyotaholic
    Florence, SC
    91 xcab...
    Looks great Mike...now I really cant wait to get my set!! :)
  12. DHPmike
    DHPmike Member
    Well I guess I better go ahead and make yours. I think the lengths on these are very good. Hit me with an email and we can work out details.
    [email protected]
  13. smctoy
    smctoy Toyotaholic
    Florence, SC
    91 xcab...
    Here is [email protected]
  14. DHPmike
    DHPmike Member
    What I will do is make 2 sets of lowers and 2 sets of uppers. Ill send you one set and have the others on the shelf for orders.
    Ill probably send you either uppers or lowers one week then the next week Ill send the others.
  15. DHPmike
    DHPmike Member
    One more update here..
    I have had some upper balljoint plates cut for stock Toyota balljoints. Im also having some cut for stock Toyota lower balljoints. Ill have pics of these as soon as I have some made.
    Im also thinking of making these available with 3/4" heim joints. Any opinions on that?
  16. beckleyota
    beckleyota Member
    Nashville tn
    93 pickup xcab
    how could u do a coiloversetup with these arms?
  17. DHPmike
    DHPmike Member
    You would simply order them without a bag plate and add the coilover mount yourself or let me know the width and diameter of the coilover mount and I could add it to the center of the lower arm. Usually they are placed about where a shock would have been.
  18. krazedprof
    krazedprof Addict
    iowa
    1991 reg cab & 1994 4runner
    ordered a set of your uppers the other day can't wait to get them
  19. IronNam
    Halloween present!
  20. DHPmike
    DHPmike Member
    Yours will be done today. while I have the jig out Im making an extra set for Toyota balljoints and two sets for S-10 balljoints.
