78 longbed -MORK
Discussion in '1976-1983 Build-Up/Project Threads' started by standardbyker88, Aug 13, 2009.
  1. beyondspexj
    beyondspexj Addict
    Sin City
    85 Pickup
    sweet! get a video up soon if you can!
  2. jdbragg
    jdbragg Enthusiast
    Acworth, GA
    If it hasn't been said yet, I'm 99% sure those are Cadillac cts wheels!
  3. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    Ill get a video soon. And yeah they are CTS rims. Looked them up online. 17x7.5+42 or something like that. Bolt right on with small spacers up front. Caps need a bit of mod to work up front. Haven't put them on yet.
  4. standardbyker88
    lynnwood, wa
    Motor still runs like a champ. It rained for the first time in a month today, so it was getting its share of slides around the corners. And through 3rd gear on a few straights :D I need to finish the interior and get it ready for sittin pretti on the 18th in Arlington. Finish the door panels, wrap the console, detail the engine bay, and repaint the underside/frame/inside of the bed all satin black. Don't think time and budget will allow for much else. But I do have a few tricks up my sleeve I'm keeping under my hat
  5. standardbyker88
    lynnwood, wa
    Here's a little project I've been tinkering with. Needs some more trimming and then glass it up. They're 82-85 celica GTS/Supra flares. Using the front out back and the back up front since those cars had wider front flares. Only trimmed the length and made the pie cut and relief lines down below. Don't need to take much off the edge that meets the body, if any. Fronts are coming along well too. I plan to trim my actual metal wheel opening a few inches all around and have exposed outer bolts for the flares. Thinking satin black for them or maybe body color.
    Here's a sneak peak. Should give me room for a dished out rim. I plan to run new 17s soon, maybe a 17/18 combo. I think a 9" +0 will work great out back :D
  6. standardbyker88
    lynnwood, wa
    I'm going for a racey look so I want the exposed bolts. The way ill do that is make a tube of fiberglass from the backside then drill it from the front with a 3/4" bit for a flange and 1/4" bit for the mount hole. Ill still have the small edge trim to keep from rubbing the paint off the body. Ill get better pics later.
  7. beyondspexj
    beyondspexj Addict
    Sin City
    85 Pickup
    I vote body color!
  8. standardbyker88
    lynnwood, wa
    Thats what I have been thinking for a long time. I have had this set of flares for years and the red is so close to my orange I always think blend it in. Make it a bit more subtle. Another guy on here has a set of the same flares blacked out and it looks good too. I'm just glad I'm not afraid to drill and cut my body to mount these suckers :lol:
  9. standardbyker88
    lynnwood, wa
    Somewhere many pages back are pics of them from a distance if you wanna see a bigger pic. Theyre on my photobucket too. They didn't look right with the steelies though. Needs a big rim on a rubber band right inside the flare to look right lol.
  10. JLau
    JLau Newbie
    Washington State
    1971 Toyota Hilux
    Recognized those wheels right away as I had a probe GT with them. If you still have the wheels I will offer you a price, pm me
  11. standardbyker88
    lynnwood, wa
    The probe wheels are long gone. They're on my buddies bagged 75. I will sell my caddy 17s for the right price. Back tires are nearly new, fronts are toast lol.
  12. 89blaster89
    89blaster89 Enthusiast
    western wa
    93 singlecab
    This is such a dope truck I'm sooooooo jealous
  13. standardbyker88
    lynnwood, wa
    Thanks man. I dig it. It's a nicely polished turd as my uncle says lol. I call his gti a girl car so its even :lol:
  14. yotarip
    yotarip Veteran
    Hey, nice yota. Love the clean body and interior. Had you considered putting in the projector headlights from the early BMW's? they will fit after trimming the plastic mounting tabs from the BMW housings and toyota headlight buckets. I use them in my early corrollas.
    I'll post a pic if you like.
    The light output and pattern is great and they look oem on the toyotas.
  15. standardbyker88
    lynnwood, wa
    Nice to get props from somebody with such a clean motor swap. And I've considered the BMW lights but prefer the look of a modern style H4. That's what I have. I need to replace one with a crack but no biggie. They perform pretty well for the junky bulbs I have in them. My next project is to tidy up the interior and add a couple more gauges. It's been pretty much done for a long time. That's why I wanna get another to start over.
  16. yotarip
    yotarip Veteran
    Cool Man.
  17. Cade01
    Cade01 Veteran
    Eugene, OR
    1973 Toyota Hilux
    I'll take you up on those pictures, I have a '73 that still has sealed beams in it and would like to upgrade. The BMW lights would be perfect for HIDs, do you use the E30 ones?
  18. standardbyker88
    lynnwood, wa
    Post them up here. Doesn't bother me. It's more info lol.
  19. first80toyota
    first80toyota Addict
    Pacific Northwest
    '77 Hilux
    I used some not-so-cheap eBay h4 conversion housings.. Fit perfectly without any trimming.
  20. standardbyker88
    lynnwood, wa
    My ebays were $70 shipped with bulbs a few years back. Had to split the stainless lock ring at the top, and grind some meat off the back of the headlight glass shape. Few minutes with an air sander and that was done. WEAR GLOVES if yours are fiberglass too. Didn't mod the buckets. I did have to cut the core support holes out larger. Mire are very deep. Not sure what pic shows that best. Ill find or take one.
