78 longbed -MORK
Discussion in '1976-1983 Build-Up/Project Threads' started by standardbyker88, Aug 13, 2009.
  1. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    motor is bored over, crank was turned, all new bearings/pistons/oil pump/timing chain. head was rebuilt last year. it should scream. if i quit messing up the tiny details that hold me up. haha
  2. oahu grown
    oahu grown Toyotaholic
    Hawaii
    92 Extra Cab
    oh wow sounds pretty beast. Thats what i want to do one day, pick up a motor on the side and build it up and drop it in. Keep this thread updated now.
  3. standardbyker88
    lynnwood, wa
    I have been keeping this updated. Today I get to go pull the front cover back off, and install an oil plug I missed. And hopefully the rear one can be access from the starter hole. I really don't want to pull the motor and trans back apart. I fought that for over an hour. The dowel pins are usually a real tight fit.
  4. butterscotch baller
    butterscotch baller Member
    Draper, Utah
    1976 Hilux
    wow.
    i just spent the last hour and a half lookin and gawking at your pics and laughing at some of the posts.. love the huge tires btw.. and i realized you and i think very much alike except for the fact your much further ahead of me.. first i do the interior then the engine and then lastly im doing the paint. but i have done a lot of the mods i see here. keep up the great work.:waytogo:
  5. Dogfather
    Dogfather Veteran
    Rochester, Washington
    1976 Toyota hilux & 77 Toyota Pickup
    Hey Bud what rig did you get the antenna off of?
  6. standardbyker88
    lynnwood, wa
    I got the antenna from some 70s datsun car in the yard. Easy install, just drill 3 holes.
    So I got the motor in, running, and I love it. It has a small leak at the oil pan gasket. I'll get that fixed tomorrow. And change the oil, adjust the valves, tweak the timing and stuff. I'll probably rejet the carb a bit richer on the mains too. Even with a stock cam, it wants fuel. Pulls real strong though.
    The bad, my header is dying. The collector is cracked, drug through, and leaking. The upper part all looks solid. I may just make an new collector for it up the hill so its not under frame level.
    I have a BUNCH of photos of me working on it today. I'll upload them, do a writeup about doing a headgasket/timing chain, and post a link here. I'll post a few general pics in here too.
  7. standardbyker88
    lynnwood, wa
    Here are a bunch of photos from today. They were taken in this order. I had the motor in, but had to tear it all back down for the two oil plugs I forgot.
    When I got to the shop today. It was already up on blocks. Hood was just sitting there.
    This was the point that I stopped the other day. Head and intake are just sitting there.
    This needs to come off :\
    After all the hardware is removed, this is where I like to pry from. Its a solid point. But don't get carried away.
    You can see the fitting I had to install above the tensioner.
    I left the head in its place for the above photos, to show people how a timing chain can be swapped without removing the head. But I suggest replacing the head gasket at the same time. Makes the job easier, and you've already got it torn down.
    Install the chain with the upper gear, and set it into the guides.
    I like to glue the gaskets down to the cover, using a very thin film of sealer. I used the high temp copper stuff for all of this. It should hold up well.
    Thin film should look about like this
    The head had been torqued and assembled, now the motor was lifted up to drop the flywheel. So I could install the rear plug.
    That little ****er
    Clean out the bellhousing inside, and try to do a better job than this. I think my old rear main seal was leaky. This trans has only been in a few months and was spotless when I first put it in.
    This is how we do motor pulls. Not as easy to do as using a cherry picker, but we don't need a paved surface for it either. Its a trade off. We built it. And yes, I do want to lay it out :D
    When in doubt, use something purple :lol: It helps steady the motor on the chain if you make a locked loop for the hook to not slide around on the chain. Or make an x from two chains.
    Tomorrow I'll get all my greasy paw prints off of the freshly painted motor, and get some photos. I'll get a video too if I remember. Atleast a walkaround clip, maybe a driving shot too if I can get the camera wedged in the seat or something. :D
  8. oahu grown
    Hawaii
    92 Extra Cab
    Wow nice write up. Always wanted to try rebuilding a motor myself but always been scared. Looking through the pics it doesnt seem as bad as i thought it would be. One question though, do you have to break in the motor now? And how do you go about doing that? I was told stay under 3K RPM for the first 10K miles, then after that should be top shape. Let me know. Thanks.
  9. standardbyker88
    lynnwood, wa
    This motor is basically just fresh crank/rod bearings, and fresh rings. And a new head gasket. Its the same cam I had before. My dads rule of thumb is "run it in different RPM ranges and gears for the first 500 miles. Change the oil the second day. And don't drive it too hard." So that's how I'm going about it. When you have a new cam to break in, you run it for about 20 minutes at about 2500 RPM then change the oil. I'll put a cam down the road.
  10. CurtisZ
    CurtisZ Addict
    Lake Stevens, WA
    1978 Pickup Longbed
  11. 77yoter
    77yoter Veteran
    seattle
    77 sr5 shortbed, 81 shortbed, 90 4x4
    its purrdy:D
  12. standardbyker88
    lynnwood, wa
    Yeah. And having a welded spider pumpkin, I should have no issues spinning both tires through the first couple gears :D
  13. white93turbotruck
    white93turbotruck Enthusiast
    i can't wait to see it too!!! it looks badass!!
  14. standardbyker88
    lynnwood, wa
    I shot me some videos! :lol:
    Here they are. For having zero choke to the motor, it starts and stays running after holding a high idle for a minute or so. Second video is a 1st/2nd/partial 3rd pull. Its raining. So I had to take it easy. That was on the way back from napa. On the same road headed there I got up to about 5k RPM in 4th. I don't have the speedo hooked up, but when I used to, that was over 100 mph. Its a 45 zone. In the video I let off about 65. :ROFL:
    <object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/gXFUXLREP94&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/gXFUXLREP94&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
    <object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/GYW0qnq4-hc&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/GYW0qnq4-hc&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
    <embed src="http://www.youtube.com/v/GYW0qnq4-hc&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></object>
  15. oahu grown
    Hawaii
    92 Extra Cab
    Wow sweet. Now all i need to do is find me another motor so i can start me a killer rebuild as well.
  16. standardbyker88
    lynnwood, wa
    I dunno why one posted twice. The other will be ready soon I guess.
  17. white93turbotruck
    sweet run!!! it sound's throty has hell!!! i can't wait to see it.hopefully my truck will be fixed by then!!!
  18. 81SR5Al
    81SR5Al Addict
    Vancouver Wa
    1980 SR5
    I did EXACTLY that last night. That copper stuff works great :cool: I'm hoping to fire mine sunday :waytogo:
  19. standardbyker88
    lynnwood, wa
    I don't know why it wouldn't show the first video properly either. But here is that other clip
    <object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/ZIiKV2MPqfQ&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/ZIiKV2MPqfQ&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
  20. standardbyker88
    lynnwood, wa
    Yes that is a Teq logo tattoo on my wrist :D
