77 RET
Discussion in '1976-1983 Build-Up/Project Threads' started by Toyotashack, Feb 23, 2022.
  1. Toyotashack
    Toyotashack Member
    Monroe, WA
    77 hilux 92 2wd 89&90 runners
    I degreed the cam to a centerline of 115.
    The first found was at 107. In the LCE video he advances the centerline to 104 after he found 110. I'll find out if it's too much when we finally get it running. I didn't get any cam info with this head I bought but It's pretty simple so it won't be much to play with it and daily it in. I'll need to buy a cam with info in the future tho.
    I go for a double hernia surgery next week so as slow as I am, I just got slower. We'll get there tho.
    Sk1dmark and Erwin Merida like this.
  2. Erwin Merida
    Erwin Merida Addict
    Long Beach, California
    LEXXXI - '93 Toyota Pickup shorty, with 5 on the floor!
    Slowly but surely!
    Sk1dmark and Toyotashack like this.
  3. Toyotashack
    Toyotashack Member
    Monroe, WA
    Scored some seats for the truck. Posted OfferUp 3 years ago. Civic seats. Pressure washed to perfection.
    My son's pulled the seats from the truck and put them in the 79 Celica we just picked up. I couldn't help it. $600 runs and drives. New clutch. I going to teach all the kids to drive a stick on it.
    Sk1dmark and Perkolator like this.
  4. Toyotashack
    Toyotashack Member
    Monroe, WA
  5. Justin Danger
    Justin Danger Toyotaholic
    Bay Area Peninsula
    If you are going with ARP studs (which you should with a turbo) you should get the 20r valve cover. They were made for dual row chains, and have plenty of extra head room for the length of ARP studs.
    ...They are also much sexier than the 22r(e) valve covers
    Erwin Merida likes this.
  6. Toyotashack
    Toyotashack Member
    Monroe, WA
    Yep ARPs. Did this to a prior build as well.
    I have a few 20r covers I think the RE covers look better than those myself.
    Sk1dmark likes this.
  7. Toyotashack
    Toyotashack Member
    Monroe, WA
    Update on where we're at.
  8. Justin Danger
    Bay Area Peninsula
    dude, get a little excited! you don't have to be such a downer.
    Time is the true test, but if there are things you don't think will last, you have to consider your options. Do you just want something to run for now and have to rebuild again and again, or do you want an engine that will be reliable?
  9. Toyotashack
    Toyotashack Member
    Monroe, WA
    Dude look at that motor! I'm am a little excited. Is my voice to monotone for you? Should I jump up and down?
    Yes time to see what an old block can take. Just a test. Just for fun.
    Like I said we'll build a proper block at some point in time. I have no problem fixing, replacing, rebuilding, or bolting a head to a block. Not hard. I have time. Reliability will come later on this thing.
    Options considered.
    _Quickfox and Sk1dmark like this.
  10. Erwin Merida
    Erwin Merida Addict
    Looking good to mee! Keep up the good work
  11. Toyotashack
    Toyotashack Member
    Monroe, WA
    Thank you Erwin.
  12. Toyotashack
    Toyotashack Member
    Monroe, WA
    Finally got the X member machined. Ready for blast and powder coat. Truck should to be pushed out this week. I have other rigs that need the shack space atm.
    Brake booster delete plate next. Promise
  13. Toyotashack
    Toyotashack Member
    Monroe, WA
    W50 and w58 X-Mem hybrid.
    Engine in truck.
    Getting there.
  14. Erwin Merida
    Erwin Merida Addict
    Awwwyeaaaa
  15. Erwin Merida
    Erwin Merida Addict
    Bro this thing is gna rip! You better mount you GoPro to it. Haha you planing on mounting an intercooler in the future? I like how they top mounted them in the mr2s..
  16. Toyotashack
    Toyotashack Member
    Monroe, WA
    Machining brake booster delete plate tomorrow.
    Then gotta figure out a push rod and spring for the pedal.
    Downpipe is on the windshield. The stack was just for kicks.
    Erwin Merida and _Quickfox like this.
  17. Toyotashack
    Toyotashack Member
    Monroe, WA
  18. Toyotashack
    Toyotashack Member
    Monroe, WA
    The intercooler is in between the grill and the radiator
    _Quickfox and Erwin Merida like this.
  19. Toyotashack
    Toyotashack Member
    Monroe, WA
    More machine work.
    Throttle cable mount.
    plus firewall hole cover. Hides some wires too.
    It should heat sink some turbo heat as well. Maybe I'll put some trick grooves in it...
  20. Toyotashack
    Toyotashack Member
    Monroe, WA
    Throttle cable plate. Booster delete plate.
    Blasted and black anodized.
    Nuts, washers and Bolts blasted and zinc plated.
    Ugly Brake rod from pedal to master. Dissected the original clutch master rod and extended 1.25" with a bolt then sleeved with what is believed to be a zinc alloy tube. I'll paint black and it will never be seen again
