Hey guys I'm new to this site and I own a stout that's in trouble right at this very moment. The Stout is my everyday driver to school this things my pride and joy, my first car the problem is I need a slave cylinder or a slave cylinder replacement and I can't find one. I've been to: Toyota dealers, Toyota specialists,autozone,napa import auto places everywhere! I just need to know are there any sites that have these slave cylinders that will fit? If you know how to get one please help I'm a teenager in need. If you do please email me [email protected]
i assume that you are meaning your clutch slave cylinder, if so the internals are standard toyota for a rebuild kit. the last one i did i just went to a brakes place with the rubbers and they had the rubbers in bulk in boxes and gave me what i needed for about $7 australian. about 10 years earlier i had a 1969 toyota dyna with the same gearbox/transmission as the stouts and a complete rebuild kit with new piston spring and rubbers from an auto place was $5 at mates rates and it fitted hilux hiace corona celica or all R series engines manual transmissions from something like 1963-1990. if you mean brakes i found that the same brake and clutch place was able to do all the rubbers and brake shoes for just under $100 for an RK101 stout and i assume you are in the US with an RK41, but all the rubbers can be obtained from the right place that fix brakes and clutches if they buy in bulk. on my RK101 the rebuild kit for one wheel cylinder and there are two per wheel from a auto place was $54 pre packaged and contained four rubbers that cost $3 each at the brake and clutch place
