65 stout costum build
Discussion in 'Pre-1975 Build-Up/Project Threads' started by goingnowherefast, Feb 9, 2010.
22r motor?
  1. leave stock for cruising fun
    10.0%
  2. mild build for little more fun
    62.5%
  3. lots of power for tire burning fun
    32.5%
Multiple votes are allowed.
  1. Dgerfan55
    Dgerfan55 Grand Toyotaholic
    lake elsinore CA
    94 pickup
    I want pics man.
  2. goingnowherefast
    goingnowherefast Enthusiast
    Haddam CT
    1965 Stout
    a few pics
    Had to rebuild the entire floor but it made it easier to fit the 93 frame.
    just made the floor pans flat.*Note where I got the steel for the pans ,their thick.
    dash on its way back in. took hours to free up the wiper arm shafts.(they needed to go in at the same time)
    mostly in,fitting the colum.
    made a custom steering shaft
    Had this short throw "riser" made from aircraft aluminum also picked up a battery tray and rad. over flow
    this is the shifter after short throwing and adding a 3spd fj40 shifter to extend it.
    Last fit for the mock motor. every thing fits!
    the stance will end up a bit lower than this,aprox 1 inch. (w/3inch control arms,2inch spindle,bj flip,215/75/r15s and 1 ton torsion bars)
  3. Enemy of the State
    Enemy of the State Enthusiast
    1985 xtra cab
  4. goingnowherefast
    Haddam CT
    1965 Stout
    some photos I took yesterday
  5. eurofreak2002
    eurofreak2002 Toyotaholic
    B-town 208
    Looking good man. Stance looks nice.
  6. delux68
    delux68 Member
    west palm beach, Florida
    87 pickup
    really wish you woulda left it red, otherwise thanks for sharing your build.
  7. GrantH
    GrantH Addict
    Hattiesburg, MS
    where did you find the hula girl? i really want one.
  8. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    lookin good, makes me wish mine was farther along....
    you said you lowered yours with torsions? my 65 has coils in front
    EDIT: never mind missed the part where you swapped out the frame
  9. goingnowherefast
    Haddam CT
    1965 Stout
    Its was more red/rust than red.:D
    my girl. sumitt or jegs maybe?:shrug:
    Well lowering with torsions is a fine tuning. Its 6in already. but yes its a 93 frame. note the frame under the nose.:waytogo:
  10. andysmiley17
    andysmiley17 Veteran
    Louisville, Ky
    82 Diesel
    wow i forgot all about this truck lol. good to see your still working on it, its coming along great!
  11. mrwizard
    mrwizard Member
    Boise, ID
    1970 Hilux
    i really love the look of those twin side-draft carbs!! very cool!
  12. goingnowherefast
    Haddam CT
    1965 Stout
    Painted with echin primer and fit up
    Clamps between each bolt holding to the roof. the roof became very strong at this point.
  13. goingnowherefast
    Haddam CT
    1965 Stout
    brakemaster and booster from the 1ton, heat sheild from a turbo truck.looking to modify the master and install two small reservors, like the early trucks and fjs.Also finished the steering shaft.
    rebuilt the oem clutch master because it had a cool look, but need the install the reservor still.
    A better shot of the cut firewall and moded firewall/trans tunnel/floor. Undercoated for sound and heat.
  14. goingnowherefast
    Haddam CT
    1965 Stout
    Needed a bit clearanced to fit the pan and sway bar. Oops! Was going to cut and weld but this was quicker. A little getto but you'll never see it.
    Added a petc*ck to the lower return hose (radiator petc*ck is blocked by the frame/Lower control strut). Reuseing a pair of LC motor mounts from my 4 Runner that were just sitting around sence the 3.4 went in.
  15. flacostaco
    flacostaco Toyotaholic
    Corona Southern Cali
    87 pickup
    damn that looks awsome:waytogo:
  16. goingnowherefast
    Haddam CT
    1965 Stout
    with the top 75% installed
    rerouting the line to the pass side for the stout.
    Just need one more turn down then pressure test em.Then drop the motor in.
  17. SAMI
    SAMI Newbie
    Canada
    86 long bed
    Awsome project! I like the rat style!
  18. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    Are rag tops hard to install? You made it seem really easy lol
  19. GrantH
    GrantH Addict
    Hattiesburg, MS
    this may sound stupid but what exactly does the pipe you rerouted do? i capped all of mine and/or took them completely off because i have no heat or AC.
  20. goingnowherefast
    Haddam CT
    1965 Stout
    Thanks
    Thanks,I'm digging it too.
    Not too bad,just take your time.It was built to order and altogether when shipped. Talk to Rick at Sliding Ragtop Kits Homepage
    Ya its for the heat and defrost.Want to use the old box.
    Dropped the motor in and installed the lc lightened flywheel, bent and installed the brake and clutch lines in the bay and fit up the header. When the rain stops in the next couple days the bed is headed over to a buddy's blasting shop (blasting the inside and underneath).
    Cleaning and hoping to install the transmission today.
