its really tight on the pass side between the fender and bumper the holes on top of the grill dont line up with the slots for on the core support i havnt cut the core support yet but it doesnt seem like it would matter to me atleast when the corners are in the grill pulls on them and has a gap between the grill and corners it wont sit down behind the bumper either
you think you might be having miss-alignment issues due to the bodydrop and not everything is aligned back up like factory? im having issues with my front bumper rubbing one of my grille corners and the other side is gapped up. my junk is crooked....lol
idk if thats its or not i mean the truck has had 3 differnt grilles in it and they all fit great except this one idk what the deal is
are you using the 4runner or 4wd corners? they are different. and you might try to adjust your bumper you should be able to move it out a little and then you might have enough clearance to make it fit.
4runner corners it looks as if the grill is supposed to sit down behind the bumper just a little bit but i have the 4 runner bumper im goin to try it soon
so if i use a 4wd fender im gonna have to get a 4wd grille also? or can i still use the 4runner grille with 4wd fenders and corner lights?
if you run the 4x4 fenders and want to run the 4runner grille you have to have the 4 runner corners the 4 runner grille and 4x4 corners are totally different and if you use the 4x4 fenders im pretty sure that you have to run the 4x4 grille also
