4runner back window project.
Discussion in 'Exterior/Body' started by MTB68TOY, Jul 28, 2010.
  1. MTB68TOY
    MTB68TOY Addict
    Jackson NJ
    Spent a couple hours playing with were to place my final cut...
    I removed the second set of bed mounts from the frame, I realized they would keep the gate from dropping even if the cut clears them
    The forward most bed mounts look like I can use as more body mounts for the extension
    The string you see in the pics is pretty close to the final cut line...
    The roof lines up but is not as wide
    The side panels are too wide so I will have to fab the side panels
    I am planning on cutting up the front doors from the 4runner to get the right shape with the dent line already there
  2. Dgerfan55
    Dgerfan55 Grand Toyotaholic
    lake elsinore CA
    94 pickup
    This is going to be a pretty cool project. Good luck man.
  3. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    Dude. I just had a brain spark happen. Since you are cool with the fatty pillar look, what about a bit triangle panel that is a seperate part look like a window louver. Sorta how some of the old mustangs were. just taller.
  4. laynlo12
    laynlo12 Member
    wow thats mad cant wait to see where this is headin. good luck with it dude
  5. IronNam
    I need to do that with the xcab....
    and throw on some rear doors..
    BWUAHAHAHAHAH
  6. MTB68TOY
    MTB68TOY Addict
    Jackson NJ
    went through about 6 sawzall blades and a few cut off disks
    not to mention grind grind grind!
    I need more blades and disks!
  7. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    Looks pretty good
  8. trap
    trap Addict
    orange county ca
    92 pickup
    that is awesome. I have always wanted this mod.
  9. JDSnake
    JDSnake Veteran
    Las Vegas
    79 longbed
    Here is another thought. Why not just use a topper?? Keep your bed, just use the back part of a topper??
    U'd get all most the same result but 10 times less work. Fiberglass is easier to work with. Gets rid of the body line problem. Move the back wall of the cab back to where ever you want it. It would be like all most doing a walk through. But all the sheet metal work would be inside the bed. You'd retain some use of the bed. Plus no need to do fiberglass bed sides or anything crazy. Kinda think like a really short trekker top.
    Then cut your topper so it functions and stuff. The topper would sit flush to the roof and solve alot of problems. Another cool thing you could do is since you move the back cab wall and stuff, you could make the topper removeable, almost like a Jeep. Half convertable.
    Actually would look cool. On second thought don't do it. I want to do it now.
  10. MTB68TOY
    MTB68TOY Addict
    Jackson NJ
    The best thing about having a mini truck is we get to do whatever we want to our trucks....
    Your idea is interesting and actually one I considered, I like what I'm doing and at this point unless it all goes to hell I plan on following through.
    I had actually planned on a full walk through with two bucket seats in the back, have the seats, cap, and a 84-89 4runner roll bar to put back there, even removed my front bed wall and sealed the bed to the cab, but decided I didn't want to do it and after many different ideas I came up with the 4runner graft...
    Oh and I'm glad you said "On second thought don't do it. I want to do it now."
    Cause I was thinking something like that about halfway through reading your post...! (8
  11. JDSnake
    JDSnake Veteran
    Las Vegas
    79 longbed
    No problem. I can't wait to see it done. I've seen one done on a off road thruck that looked really nice.
  12. MTB68TOY
    MTB68TOY Addict
    Jackson NJ
    Lots of grinding and filing today, burned through 4 more cutting disks!
    Looking much better though!
  13. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    Definitely coming along man
  14. MTB68TOY
    MTB68TOY Addict
    Jackson NJ
    I had the driver seat in today just for mock up.... felt so good to finally sit as far back as I want !!!
  15. Dgerfan55
    lake elsinore CA
    94 pickup
    Dang this is coming along fast. Looks good man.
  16. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
    awesome work!
  17. MTB68TOY
    MTB68TOY Addict
    Jackson NJ
    A little progress
    I had cut up two 4runner front doors to skin my extention with...
    but now I am probably going to cut the first part off a bed and use it to construct my cab sides....
    the extention adds 11 inches and it is 11 inches fron the front of a bed to the wheel well of the rear axle
    So if I double bob the bed it will be 22 inches shorter (or more if I bob the back extra) so the bed should be 50 not 72 inches long
    Anyway, I got the floor almost ready for welding, when the time comes I actually get my new welder.
    I really worked out nicely how the back wall has that center indent, the bracket for the gate spring fit perfectly in that spot, and the way the floor support lined up with the back cab wall to make an L bracket to connect the back wall to... almost like I knew what I was doing! LOL!
    The seat position is perfect! I can finally sit back as far as I want to!!
    Here's some pics
    Just up on the lift
    here you can see how the floor lined up
    check out how the seat leaned way back lines up with the new back window location
    another seat placement pic
    More seat placement
    headrest angle
    LEAN BACK!
    that weld nut holds the gate spring bracket
    underside
    The U channel supporting the runners floor ended up cut into an L bracket and it lined up perfect with the back wall
    got to hit all this with my new sandblaster!
    you can see how well it lined up
  18. Dgerfan55
    lake elsinore CA
    94 pickup
    Dang thats sweet looking man. Keep it up
  19. six7one_KDR
    six7one_KDR Veteran
    From Thee Island of GUAM,Live's in WASHINGTON / NO
    1976,1979,and also YES a 1973 HILUX
    are you gonna but your bed back on?cuz i was thinking you still can if you trim of a portion of the 4runner back half and seal up sum of the gaps from the inside of the bed to the runner back half.make it look like a 1/4 shell on the bed.just sum thought's,looking good tho.:waytogo:
    or dont cut the hole tail light part out and use it as a support to the bed and cover the remaining gaps from it.
  20. MTB68TOY
    MTB68TOY Addict
    Jackson NJ
    Keeping the bed and bobbing the front part
    The cab will look alot like an extracab would when done and the bed will be mounted just like normal but shorter...
