3 month time limit to finish my build....
Discussion in '1989-1995 Build-Up/Project Threads' started by mutinytattoo, Jun 2, 2013.
  1. mutinytattoo
    mutinytattoo Member
    utah
    91 toyota pickup bagged on 20s
    Cool. Ill cut the Z and drop the frame horns tonight :)
    So u did 1.25" Z correct? Then it looks like in ur build u flipped the engine cross member upside down to give you another .25"? Is that right or was I seeing things haha?
  2. Xs5875
    Xs5875 Addict
    Greenville, Ga
    1994 Standard cab 22re 5 spd
    Yes I only did 1.25"
    No, I did not flip it. If you look at it, its basically a U shaped piece of steel, with some flat stock welded inside about 1/4" lower than the tips of the U. Cut the tips off the U, so its even with that flat stock the factory welded in. Mine looks like this [o`o`\_________/`o`o]
  3. Xs5875
    Xs5875 Addict
    Greenville, Ga
    PM Me your cell number Ill shoot you a pic.
  4. mutinytattoo
    mutinytattoo Member
    utah
    Ok thatll work.. and the Z starts now haha
  5. Xs5875
    Xs5875 Addict
    Greenville, Ga
    l`o`o\_________/o`o`l
    l___________________l
    Actually more like that, notched where the oil pan would hit if you didnt do this. The round parts are bolt holes....
  6. mutinytattoo
    mutinytattoo Member
    utah
    Yea ill pull it off and cut that lip off. So did u have to notch it to clear the oil pan then?
  7. mutinytattoo
    mutinytattoo Member
    utah
    Xs5875. . Hey does it have to be Z'd that far back? Or does it not matter if I cut it farther forward? Im just wondering if it makes a difference if I cut it behind that hole or if I cut it a couple inches or so forward of that hole
  8. mutinytattoo
    mutinytattoo Member
    utah
    I was thinkin of cutting it on the line toward the back??
  9. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
    i cut mine towards the firewall. about where the black line runs across the frame vin number.
    and 1/8" is more then enough to make the Z fish plates out of. rule of thumb is your fish plate shouldn't be thicker then the parent material. the frame is about 1/8" on the outside and closer to 1/16" on the inside.
  10. Xs5875
    Xs5875 Addict
    Greenville, Ga
    That's where anti hack cut, so that's where I cut.
  11. mutinytattoo
    mutinytattoo Member
    utah
    I Z'd my frame more forward.. pretty much just copying the antihack truck a lil.. basically i cut between where the anti hack was cut and where most other people cut theres.. Got my gussets ready. Gonna weld em up in the morning.. ill drop the frame horns in the morning as well..
  12. mutinytattoo
    mutinytattoo Member
    utah
    Got a question bout the motor mounts after the z is done and horns are lowered.. if im gonna do a cowl hood do I have to dropnthe motor mounts?
  13. Xs5875
    Xs5875 Addict
    Greenville, Ga
    No. But to me a cowl hood means something mean lurks under there. A 115hp 22re isn't mean. Lol.
    The dropped motor mounts also help keep driveline angles close to the same. By Z'ng you are raising the engine, and making the trans point down.
  14. mutinytattoo
    mutinytattoo Member
    utah
    Haha true I feel the same way.. but I was thinkin of just pie cutting the hood area that's raised and rasing it a lil.. the front is the only issue of the stock hood not closing if I dint drop the motor mounts right? So its the best to just drop the motor mounts then?
  15. Under Construction '93
    Under Construction '93 Addict
    Riverside,Ca
    1993 Std Pickup
    I never saw this thread...:shrug: You can cut for z anywhere u like as long as its behind suspension and in front of steering. I cut mine a bit farther back too. You dont have to drop motor mounts either with no BD it clears hood just fine. I started to build my plates outta 3/16 but it was thick and hard to match frame curvature with so I switched up to 1/8 which will be plenty strong. I'll post pics up of the new ones sometime next week. Good luck bro! *subscribed*
  16. mutinytattoo
    mutinytattoo Member
    utah
    Right on man thanks. Yea I bought 3/16 just to make sure but yea it is a bit of a pain matchin curves haha.. I got the frame horns done and gusseted. Workin on the Z gissets now.. the whole frontend will be done tonight.. now I just need my damn tubular A arms and tranny x member to get here haha.. I might cut the rear bag mounts off tinigjt to and raise em 1" cause im 3/4" from layin frame in the back cause they are to low.. I passed on the body drop for now just cause ill do a frame later down the road.... question... how much does it change my driveline pinion by not lowering the motor mounts?
  17. mutinytattoo
    mutinytattoo Member
    utah
    Does anyone have part numbers or tell me where to buy what I need to move my mass air flow to the passenger side and down on a 45 or so degree angle with a cone filter? Any help appreciated thanks
  18. Xs5875
    Xs5875 Addict
    Greenville, Ga
    Any auto zone carries silicone 3" couplings and the "spectre" chrome plastic elbows. You'll need 2 couplings and one 90 degree elbow.
    eBay is where I bought my "cone filter and maf adapter" it was bout 20 bucks.
  19. 93_Toy_Mini
    93_Toy_Mini Addict
    Gardnerville, NV
    93 Reg Cab Pickup
    Did you have to move any of the hoses? I think the is an ac line and one other in my way of doing that.
  20. Xs5875
    Xs5875 Addict
    Greenville, Ga
    Oh yeah. I don't have a/c....edit lol
