22RE build- no turnin' back!
Discussion in '1989-1995 Build-Up/Project Threads' started by celica83_gts, Dec 21, 2008.
  1. celica83_gts
    celica83_gts Member
    Edmonton, Canada
    '90 Xtra cab 2wd
    Yeah, me too, but if you don't get it, it's just lime green....and I don't want to explain it all the time. I'm doing something else, it'll look good too. ;)
    Maybe the zinc chromate belongs on a WW2 fighter themed build. Hmmm....
  2. celica83_gts
    celica83_gts Member
    Edmonton, Canada
    '90 Xtra cab 2wd
    Okay, most of the rest of the engine is buttoned up now. Most of the parts are new, so it went together pretty nice. The valve cover is just loose (and not finish painted yet) but from there down the engine is done. Had to test fit the header, it looks great IMO. This my second 22R build, I'm hoping that I learned something from the mistakes I made on the first. This time I didn't put a too-long bolt in and hit the chain tensioner like last time. :p I tightened the bolt at the front of the head before the oil leak started this time, I also gave that part of the head gasket a coat of sealant.
  3. the_general626
    La Mirada, CA
    yea ill be the first to admit im a lil turned on haha
  4. NMTOY
    NMTOY Member
    NM
    92 extracab, 86 4runner
    That looks great!
    Robb
  5. B.Y.E.
    B.Y.E. Toyotaholic
    "671" Houston, Texas
    1982 2wd Hilux
    Looks good bro!
    Keep a close eye out on that oil pan gasket... I've had a few of them cork/rubber stuff tear and leak... I use grey RTV now on all my builds like the come from the factory...
    Can't really tell if that's a fram oil filter or not but, if it is throw it away... Throw in an extra few bucks on a good quality filter especially after a re-build/build cause you will have metal shavings and you don't want that roaming around your fresh motor...
  6. celica83_gts
    celica83_gts Member
    Edmonton, Canada
    '90 Xtra cab 2wd
    :eyecrazy: Fram alert!!! Haha, it's a Baldwin filter, we use them at work. :)
  7. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    can you give some prices on the build ? ?
  8. celica83_gts
    celica83_gts Member
    Edmonton, Canada
    '90 Xtra cab 2wd
    I'll watch it, thanks for the heads-up.... I didn't even expect to find a pan gasket in the set, but it looked like it would help to seal the imperfections in the old used oil pan. I straightened it out pretty well, but it's never gonna be new again.... I did use Form-a-gasket on the pan side, and was careful not to overtighten the bolts.
    Going by memory....
    Parts from Engnbldr- pistons, rings, bearings, metal-backed timing set, front cover, oil pump, head bolts, gasket set- ~$400 Canadian.
    Water pump from Autopartsway- $50 C.
    Machining, including cylinder head rebuild with new valves- ~$1000 C.
    Header- $350 C.
    Cam- $130 C.
    I know, I know, there are cheaper deals on reman engines out there, but this one I KNOW is good from top to bottom.
    And besides, I enjoy putting 'em together.
  9. StupidSheet
    StupidSheet Addict
    Canada
    Looks good man! Get that bad boy dropped in!
  10. celica83_gts
    celica83_gts Member
    Edmonton, Canada
    '90 Xtra cab 2wd
    It's gonna be a while... I want to put the truck in the garage, strip the box, engine and trannny, front end sheetmetal, and doors off, then paint it semigloss black. Then, the new engine and trans go in, along with the EFI conversion stuff. If all goes to plan, it'll roll out a different truck.
    None of this can be done until I finish some work on my turbo Celi and finish the rest of the garage interior....
    Wanna come help? ;)
  11. 88Sandshark
    88Sandshark Toyotaholic
    Lake Elsinore, CA
    I wish I was smart enough to rebuild my engine myself...:drool:
    Looks killer bro!:waytogo:
  12. StupidSheet
    StupidSheet Addict
    Canada
    You got just as much on your plate as I do. LOL. :D I may be tempted to drive out that way for the right Celica. ;) Oh ya and maybe a few beers!
