22r rebuild
Discussion in 'Engine/Drivetrain' started by NotAvailable, Dec 18, 2009.
  1. NotAvailable
    NotAvailable Addict
    its just the rebuild kit? for the head? and a cam?....cuz i wanna rebuild my whole head from the valves to the retainers...everything..
  2. Badlux
    Badlux Enthusiast
    Kaneohe, Oahu
    87 xtra cab
    Check the website. You can get a performance head with oversized valves. There prices are preety reasonable. Give them a call. You can build a rebuild kit to your specs.
    http://www.engnbldr.com/toyota_heads.htm
  3. NotAvailable
    NotAvailable Addict
    doesnt need to be racing but i do want it to have some power such as a cam but thats it..thx for the help bro i appreciate it...wat else do i have to remember? i dnt wanna order parts that i dont know of...like order a part i never knew existed...
  4. IBeSeeN
    IBeSeeN Addict
    Harrisburg, Oregon
    89 Toyota
    That eBay link is the same company if u call them direct they can set you up with anything you want Very good guys to work with. i got my whole kit from them Very good engine parts... Only tip i have is Tear it apart first and get it checked out to see how much u need to take out of the bores... and order your kit and give them one of the pistons to match the cylinders i did my motor a Tight bore took alot longer to break in but should last ALOT longer if u can keep ur foot out of it for 5k+ miles i would recommend it but if its questionable don't.... if it doesn't break in correctly u will have nothing but headaches.. if you have any questions these guys can help alot i might be able to answer a few questions also.. i know i have been MIA for a while but work is CRAZY... working on getting the stuff together to notch the rear of my truck and get my 5speed in finally!!!!
    PS i have the 270/430 cam i might be taking the topend apart and putting a more hefty cam this summer has great bottom end but... then topend is blah that might change after i get a header also...
  5. NotAvailable
    NotAvailable Addict
    Thanks....i have never bought anything online...I always buy things locally that's why im kinda etchy about buying it online because the hassle of getting the wrong part....thanks for the help...btw can I have ac if u go dual sidedrafts?
  6. Badlux
    Badlux Enthusiast
    Kaneohe, Oahu
    87 xtra cab
    I buy lots of stuff online. We in the middle of the Pacific and limited to whats on island so sometimes its better to just order online.
  7. NotAvailable
    NotAvailable Addict
    Very true...im really gonna look into buying that head but maybe just have mine rebuilt by a machine shop....idk yet...so much to think about...
  8. RandomHumanBein
    RandomHumanBein Member
    Charleston, SC
    '88 Base model
    If your saying its white smoke, thats coolant/water. blue smoke is oil, and black smoke is running rich.
  9. NotAvailable
    NotAvailable Addict
    i thought black smoke was your gonna die and white is oil and blue was coolant?....if wat u say is true can u help by telling me what that problem would be?please...thANKS
  10. Poorboy
    Poorboy Newbie
    Northern VA
    95 hilux 2wd 87 hilux 4wd 79 F-100 2wd
    I had 317000 on my 4wd 22re. Head gasket popped. Had some leaks, but they last for long time. I currently have 300419 on my mini. Has some leaks as well but for now it still runs good. I would say just fix yer leak and roll on.
