2024 Winter Work
Discussion in 'Maintenance/Repair' started by RetirementToy, Nov 19, 2024.
  1. RetirementToy
    RetirementToy Enthusiast
    Vallejo,CA
    1988 Toyota Extra Cab 2WD
    So my winter work this year is changing out the stereo head unit, my old unit is 10 years old,& at the same time cleaning up some wiring.
    Also running new compressor wires has when I changed from Viair 385 compressors I didn't up grade the wiring. And I am changing from fuses to the relays to breakers so can just pus a button to turn off the compressor when needed!
    Hope to get this work done before Dec, has having sugary on my right hand , & will be in a cast for a few weeks.
    Erwin Merida likes this.
  2. RetirementToy
    Vallejo,CA
    These are the wires I had to shorten, go to 3 lighted rocker switches for manual fan on over ride, shift light & sub woofer on. They are causing the switches to push forward out of position , & I just putting off the task!
      File size:
      1.7 MB
  3. RetirementToy
    Vallejo,CA
    This photo is of the wires going from 2 relays to the compressors, of which at some time got hot , wire installation did not burn but wire wrap covering started to melt . This is as when I went from Viair 385 compressor with a 30 amp draw to 485 compressors with a 40 amp draw I did not change the wiring . That is being addressed now, 10 nga wire to 8 ga wire, 30 amp inline fuses to 40 amp breakers.
    Work bench is loaded with wire work stuff.
    And new tuner getting wired up.
      File size:
      1.4 MB
      File size:
      1.8 MB
      File size:
      1.8 MB
  4. RetirementToy
    Vallejo,CA
    This photo is my power & ground supply board for compressors, fan controller & amps.
    Wire changing & clean up in the process .Had on seat out , had to pul the console so pulled the other seat , easier work area.
      File size:
      368.8 KB
