1uzfe or 2jzgte?
Discussion in 'Engine/Drivetrain' started by DROPT, Jun 12, 2010.
What motor swap?
  1. 1uzfe
    58.5%
  2. 1jz
    17.1%
  3. 2jz
    24.4%
  1. thundering02
    thundering02 Addict
    Fenton 63026
    what I think I just finished negotiating for....500ish hp?
    350 bored 30 over,12.5-1 comp pistons (keith black) summit stage two rods with arp rodbolts,clevite race bearings, crane solid roller cam 110 lobe seperation, .63 lift, intake and exhaust, chevy double hump heads with screw in studs, large dual valve springs, the intake is a victor 4+4 crane gold roller rockers, crane retrofit solid roller lifters, crane stud girdle, the block has oil restrictors installed. chrome cheverlet valve covers, stock alternator with new chrome alt brackets, newer stock short waterpump, high volume high pressure oil pump(holds 60psi oil pressure when wrmed up)
    find a trans, motor mounts, probably a radiator, driveshaft custom, few positive and negatives hooked up... and then the interesting will be the speedo.
  2. B.Y.E.
    B.Y.E. Toyotaholic
    "671" Houston, Texas
    1982 2wd Hilux
    When you guys say cheap, what exactly is cheap??? I did some looking up and the bellhousing to mount a W58 to a 1uz is over 700 bucks!! :eyecrazy:
  3. akacoke
    akacoke Member
    bayarea
    91 xcab 22re 5sp stick
    yeah , its not cheap, the motor is about 700 +tranny+adapter and other ****s you need , its above 2000
  4. MTB68TOY
    MTB68TOY Addict
    Jackson NJ
    If you can get past thinking only toyota parts will do....
    if money wasn't an issue... an ls9... 6.2l supercharged! 600+ hp 500+ torque
    now in the real world where money is always an issue... I would look for a 5.3l from a (yukon,silverado,escalade,tahoe...etc)
    they can be found with aluminum blocks and stock run from about 275-330hp 300-350ft lbs
    I have an 07 silverado steel block for my 05 GTO rat project... got it for $400 off craigs with 300 miles.... 320 hp 350ftlbs stock and with a decent cam almost 400 hp!
    stand alone computer systems and aftemarket parts through the roof for it
    no distributor in the way... and the emmisions should easily pass in most states
    (screw cali!)
    there are a ton of these trucks with this motor around...
    following from wikipedia!
    http://en.wikipedia.org/wiki/GM_Vortec_engine#5300
  5. StupidSheet
    StupidSheet Addict
    Canada
    Anyone know the weight of a 1JZwith twin turbos? There is one here for sale for $1000 with trans that I'd love to pick up for my 73.
  6. Raffaelli
    Raffaelli Toyotaholic
    Houston
    82 Longbed 2WD
    Hmm, I thought it was hard to get a 22r into a early early truck. Let alone that 6 foot long bastard :lol:
    Do et!
    Would the weight be comparable to the 2JZ? IDK. AKACOKE posted 2jz's are approx. 600 motor and 750 w/ 5 speed. Might as well have a Big block! :eyecrazy:
    Im curious what a 22R is....
  7. DROPT
    DROPT Addict
    Whales Vagina
    carbed version instead of fuel injection
  8. Raffaelli
    Houston
    82 Longbed 2WD
    :verdict_in: miscommunication error! :lol:
    I was meaning how heavy 22R/20R/22RE/22RTE series are, roughly. :waytogo:
    Im just curious, for swap knowlage
    anyone know?
  9. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
    the adapter is the most exspensive part really. thats why i'm running the stock auto :lol:
    but considering how much dual carbs for a 2xr cost, it's not too bad :D
  10. burnzya
    bodied 73 hilux
    here are some weights.. i stole em from a celica forum :D
    Here is the ultimate engine weight chart.
    Those are figures for long block plus EFI, but w/o flywheel, turbo or accessories.
    22RE - 318lb
    5M-GE - 340lb
    7M-GTE - 420lb
    1UZ-FE - 395lb
    1JZ/2JZ ≈ 450lb
    1G-GTE ≈ 385lb
    Those are for complete running order engine minus intercooler and intake piping.
    2JZ-GTE - 594 lbs w/ Getrag V160 or A340 - 746lbs
    1JZ-GTE - 700lb with R154
    1UZ + w58 ≈ 580lb
    7M-GTE + R154 ≈ 640lb
    22RE + w58 ≈ 500lb
    Tranny (w/ bellhousing)
    W50 - 110lb (steel case)
    W5X - 90lb (aluminum case)
    R154 - 125lb
    V160 - 130lb
    Auto (w/o torque converter, w/o fluid)
    A40 - 110lb
    A340 - 125lb
  11. B.Y.E.
    B.Y.E. Toyotaholic
    1982 2wd Hilux
    I'll just stick to what I know... Unless, I can get it dirt cheap or FREE then I'd try it out...
    For now tho, I :love: my dual carbs! :evil:
  12. Raffaelli
    Houston
    82 Longbed 2WD
    MMM. Ford 302 engine and trans ~ 550
    22R and trans ~ 500.
    Im gunna love that swap, get to keep that outstanding handling!
    Keep in mind a UZ swap to a 5 speed needs either a custom Bell, or adapter,
    AND a modified 1GG (i think) or custom flywheel.
    I was reading somewhere that the 1GG (whatever motor that is :shrug:) flywheel needs something like the crankbolt holes oblonged, and the starter ring beveled.
    Im no expert, look into it. Just info I can recollect right now...
  13. IronNam
    Pro-UZ swap. All aluminum motor that was over engineered with the blessed 4bolt mains and 32valves that scream "oh baby". Early 1uz rods for strength, especially if you wanna turbo/super. Minor chamber porting to remove swirlports to greatly enhance headflow. Remember, FE heads not GE.
    The uz is a light bitch relative to the 22r
    Btw, viper v10's are all aluminum... But they ARE 8.4liters... That's alot of aluminum. Stick one in the toy... Lol
  14. stihlalive00
    stihlalive00 Member
    clarence
    93 pickup
    im a huge supra fan n even tho the engine is pretty hefty the power is insane. traction would be a problem i can imagine. ive read all the engine swaps everyone has mentioned but never seen anyone talk about a 4age. is it not even an option or just not even worth mentioning? p.s. id love 400+ hp lol but i would plan it this being a street truck with some balls
  15. 94Yota_05CBR1K
    94Yota_05CBR1K Veteran
    San Diego aka SD, Daygo. Cali
    94 YoTa Mini 2wd
    Yup that's why you just pay the smog tech $200 and they're not even a friend. There's a lot of them in Cali that's willing to do it.
  16. IronNam
    LOL@4AGE
    The 4AGE I can give respect for.... but not alot. Why?
    Well okay, it's the "OMG" motor from the "OMG AE86 TRUENO SPRINTER OMG OMG OMG!".
    Sure, it's a 1.6L pushing 112hp....@ 6600RPM's... and 97lb.ft...@ 4800RPM's..
    on a 2200lb car.
    So anyway, the 22RE pushes 112-6hp@4800RPM's and 145lb.ft@3600RPM's.
    If you wanna toss the 4AGE into a hilux, run some short gears... and have fun keeping up with some 22RE's, that is if you would keep up haha.
    I'm not bashing on ya, but that's my thing on the "4AGE's and Rolla's"
  17. oldmanweaverbanzaiky
    oldmanweaverbanzaiky Newbie
    i like
    the 2rz 3rz
  18. IronNam
    so no one considered the 5VZ-FE?
  19. TheLoLux
    TheLoLux Toyotaholic
    Simi Valley, CA
    i have a 5ve at my shop. a toyota v8[​IMG][​IMG]
  20. trap
    trap Addict
    orange county ca
    92 pickup
    that's fine until a cop pulls you over for a blow off valve or obviously louder then stock exhaust. They are real hard asses about it in certain places.
    they usually pick on the hondas, but a loud vehicle is all it takes to get a cop searching under your hood in cali.
