1994 Toyota Pickup 1UZ VVTI Build
Discussion in '1989-1995 Build-Up/Project Threads' started by Luxsupra, Oct 24, 2016.
  1. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    for carpet, go to stockinteriors.com their stuff is suppose to be good quality and fitment is suppose to be top notch.
    Luxsupra likes this.
  2. Luxsupra
    Luxsupra Member
    Petersburg VA
    94 Toyota pickup, standard cab with short bed
    On my way to check that out.
  3. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
    How did i miss this thread!?
    Awesome!
  4. Luxsupra
    Luxsupra Member
    Petersburg VA
    More updates coming very soon. I am getting with Yotarip in the morning and dropping it off at his crib so he can do the wiring for me and hopefully get a first start video uploaded.
  5. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
    I'm starting to think Yotarip should quit his day job and do UZ swaps full time! lol
    I'd b bugging him if I lived near him too ;)
  6. Luxsupra
    Luxsupra Member
    Petersburg VA
    This was how Yotarip and I spent our morning yesterday. Spent it pulling my pickup with his sequoia. I have to say to have 300k plus on it his sequoia it pulled the pickup effortlessly. Toyota V8 power baby. IMAG0753.jpg
    twizted1 and grassfed like this.
  7. mutantcolors
    mutantcolors Enthusiast
    If I may ask, what's up with the flywheel that needs changed? I'm looking into slapping a 1UZ onto an existing W5x setup.
  8. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
    The 1uz never came with a manual trans, so it requires a flywheel from a 3.0? and needs a little machining to work.
  9. Luxsupra
    Luxsupra Member
    Petersburg VA
    Picked up an IS300 complete rear assembly as LSD and independent rear suspension are definitely going to improve the truck. I want to improve traction and handling as well ass have a ridiculous HP to weight ratio. IMAG0758.jpg
    grassfed likes this.
  10. mutantcolors
    Curious to see what it takes to redo the whole rear subframe.
  11. Luxsupra
    Luxsupra Member
    Petersburg VA
    The measurements we've taken so far look very promising. I'm focused on getting it up and running for the Summer before I get into that conversion. Plan to start it mid fall because it may keep me off the road longer and I wanna have some fun asap.
  12. mutantcolors
    As a guy with a blown up 22RE and waiting on an engine, I hear that. It'd be decdidely less truckish, for better or worse, but this aint exactly a sod hauling landscape truck you're building...
  13. Luxsupra
    Luxsupra Member
    Petersburg VA
    I've always been into lowering trucks but hauling capacity is usually the first thing you give up. So in return for less truckish capabilities and towing I want handling and power. The biggest reason for building a truck is it's solid frame, light weight and they'll never expect it's capabilities. I keep a full size truck or SUV around so they're responsible for the hauling and towing.
  14. mutantcolors
    Hey, I wanted to ask you about that transmission emulator. I found the guy's website but I'm wondering what you paid, if you just paypaled him or what. The engine I bought is a 1JZ VVTi I'm mating to a manual, it'd be cool if it'll work for mine too.
  15. Luxsupra
    Luxsupra Member
    Petersburg VA
    I can't speak on its use with the 1jz but yotarip has one installed on his 1uz vvti supra. It's giving him great results so I expect the same for my truck. Russian cat by the name of Yury sells them. He has done a bunch of work for yotarip with no problems to report so if said said it works for the 1jz then I'd take that statement as truth.
  16. mutantcolors
    Cool. He's got a facebook group or something yeah? Think I scanned across that in a Lexus forum or something.
  17. mutantcolors
    I emailed the guy and he said it works on any VVTi after 1998, any engine before that you just wire into park or neutral and go. Not certain if he meant early VVTi or non-VVTi only (I think they debuted in 97) but that's a good tidbit for anyone reading.
  18. Luxsupra
    Luxsupra Member
    Petersburg VA
    Small update, video is of a bare minimum, no MAF, no O2 sensor, no alternator start. We plan to add all the accessories and post another video soon. The squeaking started to clear up more with each start, engine hasn't run in nearly two years. Enjoy.
  19. Luxsupra
    Luxsupra Member
    Petersburg VA
    New video of the truck running with everything hooked up and incomplete exhaust system.
    Mr.Mini_4.0 likes this.
  20. Orlando Muniz
    Orlando Muniz Veteran
    Pflugerville, TX was Sac Town, CA
    89 Toyota Pickup
    Nice!
    Mr.Mini_4.0 and Luxsupra like this.
