1983 Toyota Pickup Project
Discussion in '1976-1983 Build-Up/Project Threads' started by 83Yota, Sep 27, 2013.
  1. 83Yota
    83Yota Member
    Arlington, WA
    83 2WD
    Big-ish Update
    Hey guys, im back.
    So while i was gone i started the body drop process, by taking off my bed, i figured since i havent done a body drop i should start with the bed because it will be a lot easier then the cab.
    I put it on the lift to loosen and remove the pins and nuts.
    After the bed was off;
    Then i went to the engine, i took the valve cover off and clean it then bought some DupliColor Engine Enamel green and black spray paint and painted my valve cover.
    Green was laid down first
    Then i took a foam brush and highlighted the raised areas in black
    With Everything out back together
    Hows she looking guys?
  2. 83Yota
    83Yota Member
    Arlington, WA
    83 2WD
    Update
    So i forgot to mention a few things with my previous updates. First being ive had a decent stereo setup in her for a little bit now, it includes;
    -DUAL head unit
    -Orion 10" Sub woofer
    -Pioneer 760 Watt Amplifier
    -2 Kenwood 7 1/4" Door speakers
    I also went to Pick-n-pull and grabbed a center console out of a 2000 Ford Focus, just so i had some cup holders, but the shift boot looks kinda cool. I also got a couple seat covers for christmas, and a "Limited Edition" Emblem/decal that is on my glove box.
    Thanks byker for the Tach in the vent hole idea i used a cheaper $35 tach. I also used some cheap graphic duct tape to cover my gauge bezel.
    Thanks byker for the mirror, i cant remember what year it is though so i can get a drivers side.
    My Girlfriend had this really cool sticker made for me.
  3. yankeetaco72
    yankeetaco72 Veteran
    Escondido
    82 short /97 Tacoma
    That sticker is classic! I want one.. Ill rock it on my truck.. :waytogo:
  4. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    Progress is coming along real nice. Glad those parts and tricks are put to use. Mirror is either 79-83 or 84-88. Those were trucks I parted years ago to acquire the parts.
  5. 83Yota
    83Yota Member
    Arlington, WA
    83 2WD
    I'll see if i can have more made, what colors? and you guys might have to pay for them i'm not sure though, But she had them made for me on Christmas, i have 3 that are green, and she even got them to put a Hilux on them which is badass i have to say she is the best.
    Thanks byker ill head to pick and pull to see what i can find.
  6. 83Yota
    83Yota Member
    Arlington, WA
    83 2WD
    Next on my list is
    -carpet
    -New floor mats
    -Fixing the door speakers
    -Sound proofing
    -and some performance parts from LCE
    i think im going to stay full 22r without going 20/22r
  7. standardbyker88
    lynnwood, wa
    For carpet go to a carpet store and get a yard or two of black. And some pad too. Cut and glue it to the floor. It's how I did mine. Off the shelf carpet floor mats I got from a camaro ten years ago on top of that. Nothing fancy. Cost about $30 to carpet. It insulated things alot too. Still loud. But helped lol
  8. 83Yota
    83Yota Member
    Arlington, WA
    83 2WD
    Thanks for the tip byker.
    Heres a couple shots of how she sits now.
  9. 83Yota
    83Yota Member
    Arlington, WA
    83 2WD
    Update
    So i cut the bump stops in half and gained about an inch more drop. The tire tucks about an inch and no need to roll fenders... Yet.
  10. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    Damn, that front end sits real nice!!
  11. standardbyker88
    lynnwood, wa
    Coming along nicely. And I think I got another mirror for ya. Got an 88 and don't plan to use the mirrors. One was broke, ill see which side is good. I have a chrome 4wd grille for yours too now. It would look really cool.
  12. yankeetaco72
    Escondido
    82 short /97 Tacoma
    I have a set of mirrors like your pass side. It came with my truck.
  13. 83Yota
    83Yota Member
    Arlington, WA
    83 2WD
    Byker let me know when you want to meet up and i can check out those parts, and Yankeetaco do you still have the chrome bumber?
  14. yankeetaco72
    Escondido
    82 short /97 Tacoma
    Ill check in my pile of parts..
  15. 83Yota
    83Yota Member
    Arlington, WA
    83 2WD
    Thanks Yankee, let me know what you have for front end wise, I rear-ended someone and now i'm in great need of a hood, grille, front bumber. I also need to straighten the core support and get a new headlight, but overall the damage isn't unfix-able it will just take some time.
  16. 83Yota
    83Yota Member
    Arlington, WA
    83 2WD
    So i think i have most of the damage repaired, I'll post pics of before and after here pretty soon, i know i'm in need of a new hood, but that's it in the line of parts i need. i'll probably head to pick n pull here in the next couple of days to get a hood off a pickup from there if its in decent condition.
  17. Aircooled
    Aircooled Member
    Kansas
    81 Pickup, 83 Pickup
    Nice! So you're running no torsion bars and basically your shocks and bumps stops are absorbing everything? How does it ride? Bottoms out?
  18. 83Yota
    83Yota Member
    Arlington, WA
    83 2WD
    The ride is really bumping, and the bump stop and tires absorb everything up front. in the back, if i had the bed an the axle would hit my frame on almost every bump. The overall ride is bad to be honest lol, but the look is what i'm going for, not ride quality.
  19. 83Yota
    83Yota Member
    Arlington, WA
    83 2WD
    Update
    So I started working on the body drop more, and I also worked on the hood, trying to get it to shut and open properly.
    Cutting the bed floor for the body drop;
    Sorry for bad quality
    The truck after the crash.
    Then after I repaired the damage. I also straightened the bumber and painted it black, replaced the factory rounded-head bolts with new bolts, for easier removal, i removed the valence so i could start straightening it, i also repainted the grille because that got damaged as well.
    while in the middle of all of this i got to drive a Porche, that was fun but I prefer my Yota :)
    It snowed a little here, my Yota couldn't go anywhere :(
  20. 83Yota
    83Yota Member
    Arlington, WA
    83 2WD
    Update progress will be slow, but good news is i have a job, so i will be able to get more parts for her, and get some wheels, any suggestions for wheels? Size? offset? what would look and fit best?
