1978 toyota pickup sr5, polished T(u)RD
Discussion in '1976-1983 Build-Up/Project Threads' started by tyrap26, Mar 14, 2015.
  1. aseq
    aseq Member
    CA Bay Area
    87 2wd, Carb, Longbed xtra cab
    Those are valve cover breathers. Often they're for show because they look kind of nice. If you use a weber carburetor for example you may need to use one or both because the air filter assemblies for such a carburetor do not have a way to accept a hose from the valve cover.
    I wouldn't say it increases the performance, and it may cause more mess(I read). The one that replaces the pcv valve would not be smog legal in California, the other one I think would be.
    http://www.lceperformance.com/Economy-Breather-Kit-20R-22R-RE-RET-2RZ-3RZ-Elim-p/3035116.htm
    http://www.lceperformance.com/K-N-Breather-w-Adapter-20R-22R-RE-RET-Valve-Cover-p/3035040.htm
    http://www.lceperformance.com/K-N-Breather-20R-22R-RE-RET-2RZ-3RZ-Eliminates-PCV-p/3035043.htm
    If you want to use a chrome K&N air filter assembly and you have an aisin carburetor you can use this this kit which has an adapter and air cleaner assembly. I don't think it would pass California smog. I would like to try one some day, but I am not sure I would like to use valve cover breathers.
    http://www.lceperformance.com/Adapter-Filter-Kit-Aisin-22R-Carb-To-K-N-Kit-p/1033010.htm
    Also see:
    http://www.knfilters.com/racing/11inch.htm
    "These filters are legal ONLY for racing vehicles. Not applicable, nor intended for use on emission controlled street or highway vehicles." ;-)
  2. skaterat
    skaterat Member
    Firestone, CO
    1977 Stepside Hilux
    I have fell in love with this pickup, so perfect!
  3. Biggja22
    Biggja22 Newbie
    Twin Falls, ID
    Looking
    I love bringing up old threads. This one is super fun and has good info for new guys. This was a good budget friendly build. Well done.
  4. Dan McBoost
    Dan McBoost Enthusiast
    NY
    78 Pickup
    i know this is truck is gone, but where in the world did you find a dash cap? I really want to pick one up, but have not had any luck finding one. Please advise, Dan
  5. nottoshabi
    nottoshabi Enthusiast
    I don't recommend it wont stay on for a long time I bought one a year ago and the glue they send with it will peel with the direct sunlight. If your dash is cracked and peeled go tot my page I have detailed pictures of how I did mine then went to an upholstery shop and had it wrapped and glued.
  6. Dan McBoost
    NY
    78 Pickup
    Mine is 100% missing, so I would like one.
  7. nottoshabi
  8. KS.ID
    KS.ID Enthusiast
    Bay Area, CA
    RN22 1972 Hilux
  9. Perkolator
    Perkolator Toyotaholic
    Placer County
    1975 Hilux
    What type of adhesive does it come with? On mine, it's held just fine and for the last 4yrs my trucks' been sitting outside in the full CA sun. Theres one or two spots I can see the adhesive, looks like E-6000/clear silicone type adhesive that the previous owner installed with.
    Pretty cool you can still buy the dash foam underneath though, I did not know that was available.
