1977 Manual to Power Steering Conversion
Discussion in 'Suspension/Chassis' started by LSUMurse, Sep 10, 2025.
  1. LSUMurse
    LSUMurse Newbie
    Has anyone ever tried a generic PS conversion kit replacing the smog pump with the PS pump? No idea if this is even remotely feasible.
  2. warmwind76
    warmwind76 Newbie
    Colorado
    1976 Toyota Chinook Camper Special, Hilux cab and chassis; 1989 Toyota SR5 Extended Cab Pickup 4WD
    Power Steering - 1976 Toyota Chinook/1976 Toyota HiLux Pickup
    This is the power steering assembly I have on my Chinook, base of course is a 1976 Toyota HiLux long bed. Adapted (probably) from the 1981 thru 1988 series Toyota HiLux 2WD pickup. I did not do the initial install of this assembly. I did however have to have replaced the power steering pump, and had a hose manufactured, in 2021 after the power steering pump went south during a road trip out to Kansas. It was relatively expensive to have it done and I do not mess with hydraulics at all. The shop was a bit confused at first because the 1976 Toyota HiLux did not have power steering standard. The previous owner had done a lot of mods, including adding the power steering, which I believe had come off a 1983 Toyota - that was of course the key to getting it replaced. The steering box is really close to the header, like millimeters, but there never has been any contact. The pump is just under the distributor. Some top views to include the fluid reservoir, and underside to showing the steering assembly.
    Hope this helps.
    83pickup likes this.
