1976 toyota stout rk101
Discussion in 'Introduce Yourself' started by YOF, Oct 15, 2012.
  1. whysmee
    whysmee Enthusiast
    62 toyopet and 76 toyota stout
    Landcruiser and dual cab dyna/toyoace, earlier the better as in some countries this style rear load deck was standard on Toyota pickups anyway
  2. YOF
    YOF Enthusiast
    WESTERN AUSTRALIA
    TOYOTA STOUT 1976 RK101
    thanks will start looking fora 1976 tray
  3. YOF
    YOF Enthusiast
    WESTERN AUSTRALIA
    would a fj45 tray fit the stout ?
  4. Rcksqrl
    Rcksqrl Enthusiast
    Boise, Idaho
    '85 4Krawler, '67 Stout
    NOOOOOOOOOOOO! dont destroy a FJ45!!!
    from what I am told on other forum ih8mud.com I believe that they will not fit. Believe the FJ45 is a smidge wider and unsure on length.
    (I can say the above as the FJ45 is almost as rare as the Stout in the states)
  5. whysmee
    whysmee Enthusiast
    45's in Australia were very very common.
    I have had a stout cab on a 75 series, mildura Victoria to bundaberg Queensland, back window to back window and they are the same width, something that surprised many that it caught the eye of and I can not find photos atm.
    It was a story I have been told a few times by some older boys is that the rk100-rk101 had the same chassis rails and it was only how the rails were fitted out to make either a 45 or stout chassis on the same production line, which I doubt is true. The cruiser have a longer cab to accommodate the larger engine, so if the stout and 45 share wheel base there will be issues and the wheel wells and arches might need cutting and grafting to suit the stout
    If you can find one of these dyna/toyoace as they are basically a cab over engine version of a stout and the stouts replacement in Australia the dyna/toyoace 1968- now http://www.gumtree.com.au/s-ad/midland/cars-vans-utes/1981-toyota-dyna-truck/1018621529 this one is a 2.4 2l diesel
  6. whysmee
    whysmee Enthusiast
    Here is a comment from a Facebook 40 series group that I am expanding my knowledge via in regards to a photo of my stout.
    That's really cool, I have never heard of them before. Would look cool mini trucked with a 40 series style side tray
  7. YOF
    YOF Enthusiast
    WESTERN AUSTRALIA
  8. whysmee
    whysmee Enthusiast
    Seriously I wish I had it, by the sounds of things that the RK101 have the same chassis rails as 45 47 so it could bolt on.
    It sounds possible that the diffs from the 40 series just bolt to the stouts springs, the holes are in the chassis rails for the cross member for the 40's transfer case and it is not rusted out like the one I ponder over for mine
    Edit
    It's in mildura and I was born there, only if I had the $ I would get one of my cousins to get it and store it til I could arrange to get it back here. Then reality hits and atm I am chasing up the legalities under the new national code of practice to put a turbo on my stout sole lpg, total head phuk and yet if I can I could be able to cut running costs down 30-50%.
    And now an explanation, lpg propane dose not suffer pre detonation and burns more efficiently at higher compression than petroleum gasoline. So as lpg is cheaper in Australia than petrol 4psi of boost more than compensates power loss and increasing boost only makes the lpg burn more efficiently and @ 7 psi swapping out the 6.1:1 diff ratio for a 40's 4.1:1 the engine should not struggle when under load as they do without turbo, thats if the test engine can handle 10 psi of boost
  9. YOF
    YOF Enthusiast
    WESTERN AUSTRALIA
    Yeah it looks nice but mildura is a long way from perth
    Keep looking I guess
  10. whysmee
    whysmee Enthusiast
    That toyoace/dyna I posted the link above is good if you think tires rims diff 2.4 2l diesel brake parts tray and it is in western Australia, it was because my dad once had one of them that I got a stout and part of me has pondered the 2l diesel swap
  11. whysmee
    whysmee Enthusiast
    I have near been going out of my mind looking at every possible angle to be able to do a collapsible steering column without major changes and it looks like this model dyna/toyoace have the closest thing to bolt on for engine swap under the national code of practice [​IMG]
    The earlier model has the same as a rk101 stout
    Edit
    Old style same as rk101 stout
    Newer style
  12. YOF
    YOF Enthusiast
    WESTERN AUSTRALIA
    mechanics 101
    stout has been running like a dream for the past months went to stat her this morning, but no go
    battery charged
    fuel in float
    sparks plugs are new
    turning over
    want avoid playing with things i no nothing about could make s mall problem worse
    would appreciate some thoughts on where to start looking for problem
  13. whysmee
    whysmee Enthusiast
    Remove a spark plug ground it and see if there is spark
  14. YOF
    YOF Enthusiast
    WESTERN AUSTRALIA
    ground plugs ? how?
    spark plugs are about 4-6months old
    could it be a coil or distributor problem
  15. whysmee
    whysmee Enthusiast
    Ground the plug by putting against earth/any steel part and turn the key, if no spark it is normally plugs points leeds coil power supply as the standard procedure is air fuel spark. Air it sucks, if not with a spark plug removed put your thumb over the plug hole and turn key, if it has compression it should blow passed your thumb no matter how hard you try to stop it (basic mechanics here). Fuel it has it and if you turn the key with a hand over the air intake on top of the carburetor it should get wet or at least smell of fuel. Spark if it does not have any check points are opening and closing that the rotor and cap do not have build up and that the carbon tip in cente of the distributor cap touches the rotor and that the coil has power, so with a test light make contact on both sides of the coils power supply(not high tension output) and turn key the light should flash and on positive side and earth the lght should glow with ignition on
  16. YOF
    YOF Enthusiast
    WESTERN AUSTRALIA
    see rubber ball like thing its getting very hot on underside when trying to start car
    as well as lead next to it that runs to battery is that the starter motor below it and could it be F*#ked
    also what is the little knob on the distributer that can be turned
  17. YOF
    YOF Enthusiast
    WESTERN AUSTRALIA
    are starter motors hard to get for the stout if need be
  18. whysmee
    whysmee Enthusiast
    Starter motors are normally interchangeable between many makes, it is normally the location of the solenoid the bit on the sides location to which side of the engine the starter mounts. When I had suzuki lj I had corolla corona gemini and Sigma starter motor all bolted in, recently I replaced the starter motor in my 1962 after buying a new battery because I could not get it to start as at first I thought the battery was stuffed and the starter motor was turning way to slow.
    The adjuster on the side of the distributor after initial timing idle 800rpm @ 10ºbtc set by turning the distributor, it adjusts timing when up in the revs or under load it lessens or increases spring tension against vacuum advance and the centrifugal of the counterweights to optimal timing and control of pre detonation that elevation climate and fuel can cause, crank angle and anti knock sensors on modern efi replace such
  19. whysmee
    whysmee Enthusiast
    The other issue now we are at this point is "the" wire, inside the distributor is an uninsulated wire that earths between the body and the internals of the distributor and as the engine revs by vacuum and counterweight the internal part moves separately to the body and "the" wire can break away from the body which can cause a break down causing the engine to misfire and carry on and if it fails to get contact altogether drives many crazy in the quest to find wtf is wrong
  20. YOF
    YOF Enthusiast
    WESTERN AUSTRALIA
    anyway to check if starter motor is rooted , before i go replacing this that & everything in between...its driving me crazy had the car for 4 or so months & have not even been around the block
    time money time....
    whats the purpose of the collapsible steering column with regards to your older post
