1976 Toyota Pickup AKA Blue Magoo
Discussion in '1976-1983 Build-Up/Project Threads' started by Ivey, Jan 14, 2020.
  1. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    They didn't straight bolt in, you would need to fab up some brackets, or just roll around barely bolted to the floor like I did. I did eventually end up pulling them and putting the bench back in though. My local mechanic told me he could get me a set of WRX seats for $200, just waiting to get around to cleaning up the cab (new floor pans and carpet).
  2. Erwin Merida
    Erwin Merida Toyotaholic
    Long Beach, California
    LEXXXI - angry '93 ShortBed
    Anything interesting come out?! Haha and you definitely want a new T housing. Flat matting surface is key to no hose leaks
  3. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    Yeah new T housing is on the way, also have a new thermostat and sensor to go with it. The engine side of the drain was completely clogged with debris. It was so bad I had to break it up with a pick to get it to drain. Should be good now. I ended up flushing it around 6 or 8 times before it came out sufficiently clear.
    Erwin Merida and nottoshabi like this.
  4. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    I'm on a roll. Kill switch installed on the fuel pump, uses a wireless trigger. Horn fixed (oooga oooga!), new door seals and even got the radio kinda working. Still need to figure out what steering wheel setup to go with. I can't find the Grant "no wheel, no steal" kit, already had one order cancelled due to no stock. Might go with the NRG setup with the locking hub but I'm still trying to figure out what adapter/hub configuration I need.
    Getting dangerously close to moving on to the cab which means fixing the floor pans....
    Erwin Merida likes this.
  5. nottoshabi
    nottoshabi Enthusiast
    These guys don't have it either?
  6. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    Nope it's unavailable when I try to add to cart.
  7. nottoshabi
    I think I saw it at pepbopys or auto zone as well on the shelf, this was pre pandemic. Things might have changed but wont hurt to ask.
    Ivey likes this.
  8. Justin Danger
    Justin Danger Toyotaholic
    Bay Area Peninsula
    I had looked into an NRG quick release a while back, but with the adapter for our steering colums, the quick release mechanism, and all that jazz, it seemed like it would stick out 4 inches farther.
  9. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    You will be able to use most toyota hubs. I think I used a mrk4 supra one. The nrg are solid hubs and can help keep the stick out short. If you put a quick release you lose all that. They do have a slim version but that only works with a crush hub. Much safer in a wreck when compared to the solid. I went with the crush and a cheap slim quick release that I had used on my sim rig for a year before calling it safe for the truck and buying another one. It sticks out kind of far. Even with my long arms I don't find it bad. Then again I always liked the feel of a close wheel.
  10. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    Yeah my biggest worry is the steering putting the steering wheel too close.
    Perkolator likes this.
  11. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    Added some little headlight shades I’ve also got a new left side splitter piece coming the right side managed to make it home 65F1A2D3-2EB4-40CC-BA5F-1B1316BFE2DD.jpeg
  12. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    You do go a little more room in the later model. You can do a flat face wheel as well if you want to gain some more.
  13. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    Ended up going with a NRG setup, I'll let you know how it works out
  14. Justin Danger
    Bay Area Peninsula
    Which hub did you go with?
  15. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    I went with the NRG SRK-120H Steering Wheel Short Hub and NRG SRK-200BK Quick Release gen 2.0. I'm also going to pick up the locking cover assuming it all fits nice.
  16. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    Oh man going to be hot boying it up with the nrg. Better make sure it dings. Lol
    What wheel you going with?
  17. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    14" wheel. I also got my oooga oooga horn working so be on the look out! Screenshot 2021-12-22 082615.png
  18. nottoshabi
    Let me know if you get the horn working. Can you take some pics a long the way?
    Peter T and Ivey like this.
  19. nottoshabi
    It will be impossible to keep that white clean, I had one on my Cadillac. The white lasted one week. I got rid of the wheel a month later cause I could not clean it good enough to be white again. The oils from my hands got in to the plastic/rubber and stained it could not get it out again.
  20. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    Might need to invest in a pair of driving gloves!
    nottoshabi likes this.
