1970 hilux project
Discussion in 'Pre-1975 Build-Up/Project Threads' started by d&l fab, Jun 6, 2009.
  1. d&l fab
    d&l fab Member
    perris
    1970 toyota hilux 1964 datsun 320 1954 chevy belair
    Ya I'm gonna use bushing for the lowers and maybe helm for the upper arms
  2. swapmeet
    swapmeet Enthusiast
    LOL I can answer these questions, cause i'm dealing with these issues currently.
    The Lowers are going to interfere first. But if you change out the hardware (flip the bolts) and shave the corners on the inside you should be able to lay. (BTW, i'm only guessing on this, and I do believe that this interference will cause the most difficulty)
    The crossmember is lower than the frame, but its sort of bubble shaped piece of sheet metal, so I plan on cutting that out, and plating it flat with some 16 or 12 gauge....
    The drag link will hit as well, but you can heat and bend the pitman and idler arm about 1/2-3/4" to lay completely and there is plenty of room to adjust more than that if you desired.
    I'm about 1/2" from laying completely and all i've done is shave the corners of the lowers. Sorry if this is thread jacking... :doah:
    I agree the lowers arn't optimal or attractive, but I don't possess the skills to fab lowers myself.
    I'd be intrested in buying a set of lowers from you possibly if you make some... let me know.
  3. Sal-G.77
    Sal-G.77 Enthusiast
    Palmdale CA
    90 4RUN/22RE/2WD
    :waytogo: Sweet Truck.. I like what you've done to it...
  4. ir1d3d1rt
    ir1d3d1rt Newbie
    8r and 18r are the same block, just swapped an 8r for an 18r.
  5. d&l fab
    d&l fab Member
    perris
    well i havent worked on my truck for about a week, been busy working as much as i can, but im supposed to be getting laid off soon so i guess ill have some time then to work on it, lol, well heres some pics i got, removed the cross member and suspension
  6. d&l fab
    d&l fab Member
    perris
    ill probably start making the new front crossmember this weekend if i dont work
  7. swapmeet
    swapmeet Enthusiast
    Looks good!
    I don't feel so bad for cutting as much as I did out on my spring cups now.
    What size bags are those?
    Also, are your ball joints maxing out?
  8. d&l fab
    d&l fab Member
    perris
    Slam r5 in the front, the ball joints where almost maxed
  9. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
    soooooooooooo, what r u doing with that 18r?
  10. d&l fab
    d&l fab Member
    perris
    not sure yet, i might get sam78's 20r if i do then ill probably put the 18r up for sale
  11. burnzya
    bodied 73 hilux
    o.k. let me know please!
  12. d&l fab
    d&l fab Member
    perris
    Ok guys I'm selling my hilux, I'm moving into a smaller place and I'm gonna open a shop with a friend so I really need the cash and less projects, asking 1200 obo thanks [email protected]
