1965! Toyota Stout
Discussion in 'Vehicles' started by Shadetree, Nov 2, 2020.
  1. Shadetree
    Shadetree Newbie
    Upper left USA
    65 Stout
    1965 Toyota Stout
    The truck was used on a ranch in Oregon before it was acquired as a non-running project. Subsequent work to bring it to running condition included servicing the brakes and installing a Weber carburetor, a replacement exhaust system, fuel lines, wheel cylinders, new battery, new alternator. distributor cap, rotor, spark plugs, driveline has new bearings and has been balanced, new fuel lines were installed. All wiring brought back to stock and all gauges work!!!!!! (Except for temp, aftermarket temp gauge installed under dash!!!!!)I have records beginning in 2017, spare parts, and a clean Washington title.
    The 1.9L 3R-B inline-four has been fitted with a Weber 32/36 DGV carburetor and is linked with a four-speed column-shift manual.
    This is Toyota’s first import to the USA. Only 4000 sold and most have since found their way to the crusher. F45087B1-A57F-4B61-99E2-D93DACD80511.jpeg 48D73E69-8D80-44CD-A558-7A18DCA392F9.jpeg
  2. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    Nice rig. I'm confused by it being the first toyota import in America. Toyopet was in America first in the 50's then the land cruiser.
  3. Shadetree
    Shadetree Newbie
    Upper left USA
    65 Stout
    I apologize first Toyota truck
    Justintheegreat likes this.
  4. Eddietech
    Eddietech Newbie
    Is this for sale? I’m not seeing a price. Sorry if I missed it.
  5. Shadetree
    Shadetree Newbie
    Upper left USA
    65 Stout
    Yes it is. Asking 17k but love a good trade
  6. Eddietech
    Eddietech Newbie
    She’s a beauty, where did you end up finding spare parts for it?
  7. Shadetree
    Shadetree Newbie
    Upper left USA
    65 Stout
    Thanks........ well it depends.
    how far along is your project? What do you need? I can pass on some places that helped source parts.
    a lot of stuff came from Australia as they still have plenty of stouts there.
    some shit I had to completely rebuild.
    anyways let me know how I can help you and I’ll try my best my good man
  8. Smithtattoo
    Smithtattoo Newbie
    San Francisco
    Did this truck ever sell or do you still have it?
  9. Eddietech
    Eddietech Newbie
    Shade tree.
    What's up bro sorry been swamped here's the list it's probably about 80% of what we need.
    Stout parts
    Front bumper hardware
    Headlamp bulbs
    Headlamp brackets.
    Headlamp Hardware screws and bolts
    Headlamps wiring
    Marker lamp seals. And bulb's
    Marker lamp screws
    Marker lamps wiring
    Grill Hardware.
    Grill seal between Fender and Grill
    Right and left Fender Hardware..
    Right Fender air duct tube
    Cowl Hardware
    Cowl seal
    Hood Hardware
    Hood hinge bolts
    Hood seal
    Wiper blades
    Sun visors are done but we need the bases to mount them
    Inner window cranks
    Re key door lock cylinders
    Rt and left door lock cylinder seals
    Right and left door handle gaskets
    Right and left door glass run Channel
    Rt and left door side view mirrors
    Restoration of door glass
    Ignition switch
    Dash wiring
    Stereo
    Antena
    Seat Hardware
    Seat belts and Hardware
    We need new gauges Volt. Oil. Temp
    Restoration of Tac
    Restoration Repair of tac housing
    Ashtray restoration
    Steering wheel components for Horn
    E-Brake cables depending on rear end.
    Clutch? Or switching to Auto?
    Drive shaft
    U bolts for drive shaft
    Upper radiator hose
    Lower radiator hose
    Belts
    Paint heat shield
    Ford 9in rear end and all drum brake components
    Rims.
    Tires.
    Master cylinder and booster.
    Brake lines from master cylinder to front brakes.
    Proportioning valve.
    Brake lines from master cylinder to rear brakes.
    Gas tank hoses and caps
    Battery
    Battery cables
    Battery pad
    Floor is still loose below driver seat do you want us to reinforce it?
    Tailgate hinges
    Front and rear shocks
    Wiring to rear lights
    Turn signal components for dash
    Exhaust
    Fabrication of headers to exhaust
  10. jetas
    looks like you need EVERYTHING short of a body and frame.
    Electrical, buy yourself an aftermarket harness and wire it up, not as hard as you think.
    Brake lines, buy the tubing and fitting off amazon, i think i paid less than $50 when i redid all of mine.
    hardware, go to the junkyard and take as much as you can from a newer truck or better yet, grab a thread pitch gauge and make not of everything you may need and buy it new, theres some real nice zinc plated bolts out there.
    rockauto may have all the repair parts you need
  11. Eddietech
    Eddietech Newbie
    Thank you!
    I just forwarded the list over to shade since I totally owed him a response. Most of the items should be doable but there are some where I’m sure we’ll have to make or figure out how to use an older trucks.
    But good recommendation, I’m gonna have to see if I can find old trucks out here at the pick your parts and grab them.
    Thanks again
    jetas likes this.
  12. jetas
    What engine do you have in there? JZ?
  13. Eddietech
    Eddietech Newbie
    2jz LOL
    jetas likes this.
  14. Erwin Merida
    Erwin Merida Toyotaholic
    Long Beach, California
    LEXXXI - angry '93 ShortBed
    Looks like a 7mge.. ? Either way looking good.
  15. Eddietech
    Eddietech Newbie
    Thank you!!
    it’s a 2jz motor with a manual transmission.
    cant wait to finish it this year !
  16. Justintheegreat
    Justintheegreat Member
    Bay Area CA
    1986 Xtra cab
    wow. so bad ass man!
    Eddietech likes this.
