the yota
Discussion in '1984-1988 Build-Up/Project Threads' started by taa84, Nov 26, 2009.
  1. taa84
    taa84 Member
    87 yota
    i have had this truck forever. 7 years ago i bagged the front and painted it and then the motor **** out on me and its been sitting ever since then. so i finally started on it about a month ago i got the c notch in and just getting all the parts for the rest of the 4 link so i can weld it in. i picked up a ford 302 yesterday to put in it after i clean it up and paint it and put a little cam in so it sounds good. let me know what yall think about it
      File size:
      44.9 KB
      140
      File size:
      31.8 KB
      138
      File size:
      38 KB
      148
      File size:
      31.1 KB
      138
      File size:
      38.7 KB
      150
  2. taa84
    taa84 Member
    87 yota
    test fit the 302 i have fig its going to be easyer to take the cab off now im tryin to fig out if i want to stock floor it
  3. burnzya
    nice! is that a c4 tranny?
  4. taa84
    taa84 Member
    87 yota
    no its a aod but im looking for a c4 i heard that the aod trannys have alot of probs so i dont want to get it all in there and have mess up on me
  5. StupidSheet
    StupidSheet Addict
    Canada
    Cool project! Glad to see you decided to go with a Ford instead of a bowtie like everyone else that swaps to a V8! :waytogo:
  6. burnzya
    i've heard the same of the aod trans. i have a c4 in my 66 mustang, and with a shift kit those little trannies are pretty solid.
  7. taa84
    taa84 Member
    87 yota
    thanks man i always have been a ford guy
  8. taa84
    taa84 Member
    87 yota
    yea im tryin to find one cheap but im not in a hurry i still have to tear down the motor and put new gaskets on and check out all the internals and put a cam in it
  9. Reddawg007
    Reddawg007 Member
    Memphis, Tn
    88 Reg cab 22r
    I'm gessing that since most of are trucks have little to no wiring going to the engine if you have a 22r then I guess its not that hard to put a V8 in it thats has a carb. I was thinking about putting a 1jz in but after I lost my job and access to a lift an power tools I havebeen thinking about a V8 maybe a 302.
  10. taa84
    taa84 Member
    87 yota
    1jz would be nice but a 302 is cheaper there are only just alittle wiring to it if you are doing a carb its not bad at all. i fig out that it is easyer if u take off the cab
  11. krazedprof
    krazedprof Addict
    iowa
    1991 reg cab & 1994 4runner
    looks good. im going the same route with a 302 in mine
  12. taa84
    taa84 Member
    87 yota
    thanks bro yea i cant wait to get it done
  13. krazedprof
    krazedprof Addict
    iowa
    yea me either but i gotta finish my bodydrop before i can put the motor in mine
  14. taa84
    taa84 Member
    87 yota
    yea im tryin to fig out if i want to stock floor mine or not
  15. camel84
    camel84 Member
    Ontario, Ca.
    84 xcab 22re
    Who said a 302 would be cheaper than a 1jz? maybe if you already have a 302 block hangin round. just wondering cuz i just bought a 1jz gte for a grand with trans and everthing. not to say i wouldnt put a small blocking in it eigther.check out Jegs they have floor pan parts cheap , there not fot a toyota but u can trim to fit.
  16. taa84
    taa84 Member
    87 yota
    i got the motor and trans for 200 running after i get done with it im guessing i will have around 600 in it
  17. 2farsouth
    2farsouth Newbie
    Southern Iowa
    94 F-150 (clifford)
    how does the oil filter look? how close does it get to the steering box?
  18. Predracer
    Predracer Toyotaholic
    Conyers, GA
    Long bed 80 2rz turbo machine
    Yea a 302 is way cheaper to swap than a 2J and is going to be real cool. Def get a c4 and you're set. looks like a sick project man.
  19. camel84
    camel84 Member
    Ontario, Ca.
    84 xcab 22re
    2 bills for a runner itsnt bad, summit carrys a header that will fit , illtry to find the link for ya . post some more pics.
  20. 73TRD
    73TRD Veteran
    Redding, CA
    84 sr5 standard cab short bed, 73 hilux short bed
    check out advanceadapters.com
