92 toy project
Discussion in '1989-1995 Build-Up/Project Threads' started by CajunTaco, May 13, 2009.
  1. nvrenufedge
    nvrenufedge Grand Toyotaholic
    Caldwell, ID
    bagged '93 std cab
    Nice work! :waytogo: Your truck is really coming along nicely.
  2. CajunTaco
    CajunTaco Enthusiast
    Louisiana
    92 Reg Cab
    More updates. Got the floor finished. Need to finish welding the back wall, and do the cab supports underneath. Does anyone have pics of reinforcing the cab supports?
    -Ryan
  3. Shadetree Mechanic
    Shadetree Mechanic Addict
    Emerald Triangle, CA
    Nice work! You did a really nice job on the filler plates! I like the angles.:waytogo:I'll do the reinforcing on my body mounts this weekend and get some pics up after that. I still haven't done mine...
  4. stll2hi
    stll2hi Member
    Temecula, SoCal
    92 xcab & 98 Taco
    Nice work!!
  5. CajunTaco
    Louisiana
    92 Reg Cab
    That would be awesome!
  6. burnzya
    lookin great man!
  7. smctoy
    smctoy Toyotaholic
    Florence, SC
    91 xcab...
    great progress
  8. bustedknuckles
    bustedknuckles Enthusiast
    Las Cruces, NM
    1985 Toyota, 2000 S10 Xtreme
    Its looking really nice. Keep up the good work
  9. CajunTaco
    Louisiana
    92 Reg Cab
    Thanks
    Thanks guys! The nice comments are what keeps me going!
  10. CajunTaco
    Louisiana
    92 Reg Cab
    Well I put in about 5 hrs after work today. Got the driver's side cut and moved the clutch (Finally...). So here's the pics:
    First off cutting the cab for the wheels. Toyotas make 18's look huge...hahaha
    Then I went and relocated the clutch. Everyone does it differently, but this is the way I chose. I pushed it up into the cowl, right under the wiper linkage.
    Gettin to it. -Ryan
  11. standardbyker88
    looks good bro. i like it. just be careful on hard launches and 1st to 2nd shifts if you are still running the stock axle size and tranny. lol. ka boom!
  12. CajunTaco
    Louisiana
    92 Reg Cab
    Another update. Got the driver's side mostly finished. Made way for the wiring and put the engine in for ****s and giggles. It'll come out tomorrow and then go back it with the trans.
  13. smctoy
    smctoy Toyotaholic
    Florence, SC
    91 xcab...
    looking real good
  14. CajunTaco
    Louisiana
    92 Reg Cab
    worky worky
    So its been a while but I finally worked on it. I got the trans tunnel worked out, just have a few bits to finish welding. Then I need to finish the floor by the wheels, and finish welding the back of the cab. I can't wait to get this thing back on the ground. I feel so close, but so far...
  15. Toyota530
    Toyota530 Veteran
    94 toy xcab
    r using stock arms?
  16. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    maybe a dumb question but since you had to build a tranny tunnel and did a body drop, would it be a smart idea just to put in a entire new floor ? so that way you can have an all flat surface and it would be a ton easier to build whatever brackets you may need for seats and stuff.
  17. standardbyker88
    with flat floors, you have to do more bracing underneath. looks clean, but its alot more work. the stock shape with all the ribs and bends adds alot of strength with just the metal.
  18. the_general626
    La Mirada, CA
    plus if im not mistaken, all ur really doing is just adding some odd inches to the length of the tunnel (well thats one way other than building a new one) and the floor so its kiinda simpler to use the stock floor
  19. CajunTaco
    Louisiana
    92 Reg Cab
    Yes, I'm using stock arms upper and lower. Lowers were cut and plated for the bags.
    I only had to rework the trans tunnel where it met the firewall because the v8 bellhousing was so large. So it was only a small area, not too bad.
    I am running 92 Nissan 240 buckets which fit the truck almost perfect. Bolt into the outside front mount, then I put nut-certs for the rest. But they fit the floor good.
    -Ryan
  20. standardbyker88
    sweet. i like those seats. my friend has a 240. comfy stuff. post pictures when you get them installed.
