LC pro crank and light flywheel
Discussion in 'Parts and Accessories' started by sirdeuce, Dec 25, 2023.
  1. sirdeuce
    sirdeuce Veteran
    '86 4Runner and '89 2WD
    I have an LC knife edged pro stroker crank and light, 12lb, flywheel I'll most likely never use. Any interest?
    Flywheel has not been installed and the crank was used in an engine for about a thousand miles. The combination revs like a 4AGE.
    Like everything else these days, I want millions for it, but I'm sure We could settle on some far south of that.
    Why am I selling? Getting old and it's a project that has found a spot on the back of the shelf. That and I'll likely sell my 2WD shortly after I get my 4X4 going.
    Erwin Merida likes this.
  2. Erwin Merida
    Erwin Merida Toyotaholic
    Long Beach, California
    LEXXXI - angry '93 ShortBed
    What happened to the rest of the motor? Pics?
  3. sirdeuce
    sirdeuce Veteran
    Pics? If I could ever figure how to post them, I would.
    The rest of the motor? The rods that came with the crank had these thick ass bushings to adapt a piston with a smaller diameter pin. I ran it and it made a noise I didn't like. Turned out those bushings slid out and cause a rock in the pistons. Tossed the pistons and the rods, built the block back to stock, budget didn't allow a grand for new rods and pistons, bagged the crank and put it on the shelf.
    Thought about reviving the old project, even bought the LC 12lb flywheel. Now I've decided to just get this 4X4 going and lose the 2WD and 4Runner. As soon as th 4X is broken in I'll sell my '89 beater. The 4Runner is up for grabs now.
    Erwin Merida and MrDinkleman like this.
  4. Erwin Merida
    Yea, life take those curves! Cars and trucks come and go. We just gotta remember to have fun and enjoy them while you have them.
    Man that crank gives about 20 cid! Would make for a nice high compression build. Choppy efi pro cam and mega squirt
  5. Erwin Merida
  6. sirdeuce
    sirdeuce Veteran
    My first stroker, before I even heard of LC Engineering, was a 94mm stroke with 93mm custom pistons from ross with Chevy journal 6" rods made by Mechart. Had a 20R head with 2mm oversize valves and ported to the max. Custom 1 5/8" headers and 45mm SK carbs 290/280 duration cam with .470 lift. '77 Celica running low 14s, in 1985.
    Those were the days.
  7. Erwin Merida
    Maann. That must have been mighty awesome!
  8. sirdeuce
    sirdeuce Veteran
    It was a lot of fun! At the time most of my efforts were going into Beetles, but I had to something to battle the Honda guys.
  9. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    If it's still around after some time I might buy it. Just about done building the daily and figure I should start on the Hilux when I'm done.
  10. sirdeuce
    sirdeuce Veteran
    Having a 22R that revs freely is a kick!
  11. sirdeuce
    sirdeuce Veteran
    Still have this crank and flywheel, recently acquired a block I can add to the post. Block is std. bore and mains are straight.
