New member
Discussion in 'Introduce Yourself' started by N & S, Apr 23, 2024.
  1. N & S
    N & S Newbie
    Tennessee, USA
    1994 Pickup Dlx ext.cab 22RE
    Hello,
    I’m new to the group and this is my first build of an import of any kind. I grew up 3rd generation in a mechanic shop but have been retired for several yrs. Block is in the shop now, looking forward to learning new tricks. As I mention this is my first import build and right out the gate on a stock motor. I learned someone had took a hand sander to the deck surface of the block. It was .017 interference on #1 piston and .024 on #4. I actually decked it by hand with plate glass 100-1200 grit and straighten the deck, but once I realized #4 pin was loose from the harder compression, I pulled the block.
    Erwin Merida likes this.
  2. Erwin Merida
    Erwin Merida Toyotaholic
    Long Beach, California
    LEXXXI - angry '93 ShortBed
    Welcome aboard. So are you going with a thicker Head gasket?
