Control Arm bushing in the way
Discussion in 'Suspension/Chassis' started by SupremeCling, Apr 11, 2022.
  1. SupremeCling
    SupremeCling Newbie
    Denver, Colorado
    89 Pickup
    So I found some excellent wheels, but they graze the nipple diving up from the control arm bushing
    1989 pickup, 100% OEM
    Was looking at some 17x9 +40 wheels
    Is there such thing as a "low profile" control arm or even an aftermarket control arm that is more descrete I space?
    All I can find are 4x4 lifting related control arms. Lowering kits seem to not include control arms..well some do but I'm not sure if it solves the problem
  2. Erwin Merida
    Erwin Merida Toyotaholic
    Long Beach, California
    LEXXXI - angry '93 ShortBed
    Use a spacer behind the wheel. If it's nearly grazing then you'll only need 1/4" or 1/2".
    SupremeCling likes this.
  3. jetas
    Is it the zerk fitting on the control arm that its hitting? If so just replace it with bolt that fits in its place. Or run a 5mm spacer if that will be enough to give you the clearance needed
  4. SupremeCling
    SupremeCling Newbie
    Denver, Colorado
    89 Pickup
    Wow..real pro knowing what was rubbing.
    It's definitely the zerk fitting...didn't even know what that was
    jetas likes this.
  5. jetas
    I know people have said they had that issue when they had drop spindles and small wheels. Must be the offset of the 17s causing your issue.
