So I found some excellent wheels, but they graze the nipple diving up from the control arm bushing 1989 pickup, 100% OEM Was looking at some 17x9 +40 wheels Is there such thing as a "low profile" control arm or even an aftermarket control arm that is more descrete I space? All I can find are 4x4 lifting related control arms. Lowering kits seem to not include control arms..well some do but I'm not sure if it solves the problem
Is it the zerk fitting on the control arm that its hitting? If so just replace it with bolt that fits in its place. Or run a 5mm spacer if that will be enough to give you the clearance needed
Wow..real pro knowing what was rubbing. It's definitely the zerk fitting...didn't even know what that was
I know people have said they had that issue when they had drop spindles and small wheels. Must be the offset of the 17s causing your issue.
