S10 axle install
Discussion in 'Suspension/Chassis' started by 4lo4fun, Jan 3, 2022.
  1. 4lo4fun
    4lo4fun Enthusiast
    Layton, UT
    78 hilux
    Finally got the s10 axle with 3.42 gears and factory locker installed over the weekend.
    It is currently lowered with 3 inch blocks, but I forgot to install the 2 degree shim. Now my pinion is sitting sitting at 13 degrees up and the trans is 3 degrees down. Will the 2 degree shim be enough to bring the pinion down to where it should be?
    I also need to find or make shackles for the leaf springs that relocate the leaf about an inch outward so I don't destroy bushings. Does anyone know of somewhere that I can find these?
    Whats the width on the axle WMS to WMS?
  3. 4lo4fun
    4lo4fun Enthusiast
    Layton, UT
    78 hilux
    The toyota was 55 inches and the s10 is 54.5 inches.
  4. fred heath
    Google “offset shackles”. Lots of aftermarket shops sell universal and custom made.
  5. jetas
    I may have to look into this for myself
    4lo4fun likes this.
  6. 4lo4fun
    4lo4fun Enthusiast
    Layton, UT
    78 hilux
    Fred, I've been looking online for some, but most of them are outside my current budget.
    Jettas, downsides are that you will need adapters to go from 5x4.75 to 5x4.5 and the leaf spring being kicked out in the rear. But if you are 4 linked, that wind be an issue. Also adapting the brake lines, but that's not hard is you know how to flare them.
  7. jetas
    Never looked into it much but i wonder if its a stronger diff than the toyota unit. Or if there are more options for replacement axles after shortening
  8. 4lo4fun
    4lo4fun Enthusiast
    Layton, UT
    78 hilux
    Why would you need to shorten it?
  9. jetas
    Tuck the wheels a little more, run wider wheels with more offset
  10. 4lo4fun
    4lo4fun Enthusiast
    Layton, UT
    78 hilux
    That makes sense.
