Replaced both control arm bushings at same time - truck drops to the ground
Discussion in '1989-1995 Pickup Discussion' started by Bradley Allen, Apr 8, 2021.
  1. Bradley Allen
    Bradley Allen Newbie
    Colorado
    94 Toyota Base 2wd
    Hey All - the saga continues...
    I have a 2WD 1994 Toyota Base.
    I have just replaced the entire suspension and steering components.
    How do I set the control arm bushings at ride height when I've replaced them both at the same time? When I lower the truck, it drops almost all the way to the ground.
    PS - I have installed Belltech Lowering Spindles.
    Thank you in advanced!!!
    Must have forgotten to readjust the torsion bars
  3. Bradley Allen
    Colorado
    94 Toyota Base 2wd
    I feel like I cranked them down...I guess I'll throw more turn on it. They are Sway-A-away Bars.
  4. jetas
    That or the key may not have been turned enough to put the necessary tension on the T bars
  5. Bradley Allen
    Colorado
    94 Toyota Base 2wd
    Hmmm interesting thought. I did line everything up with the notches. You're probably right with the tension - and I won't be able to get under there again until tomorrow.
    jetas likes this.
  6. Liquidhandwash
    Liquidhandwash Enthusiast
    Northen VIC
    1980 diesel
    I did mine recently, I marked the spine before I pulled it apart, I'm pretty sure you can put the spine in any spot it has no master spine, and when I put it together the angle of T bars was sitting lower than I expected, but after tightening them the ride hight was correct, I guess that's why the adjustment bolts are so long, you need most of the thread to install the torsion bars.
  7. Bradley Allen
    Colorado
    94 Toyota Base 2wd
    Yup, y’all were correct wrenched down on the T bars. Over 70mm exposed.
    center bar under the pan is about 6.5 inches from the ground. See pictures. Thoughts?
    images are potato quality. all I could upload from my phone...
    jetas, Ivey and Erwin Merida like this.
  8. Justin Danger
    Justin Danger Toyotaholic
    Bay Area Peninsula
    that looks like a nice drop, and your undercarriage looks so clean. keep it up man!
  9. Bradley Allen
    Colorado
    94 Toyota Base 2wd
    Thanks Justin! I have replaced so much with this restoration.
  10. Erwin Merida
    Erwin Merida Toyotaholic
    Long Beach, California
    LEXXXI - angry '93 ShortBed
    Yea that's definitely turning out mint! What parts did you go with for suspension/steering? Did you piece it together or did you buy a kit? I ask because this is highly important on my build and been hesitant to buy the Amazon/ebay kits..
  11. jetas
    Rockauto bro. Moog/mevotech most of all of them are the same shit. 555 cast into the parts
    THorn and Erwin Merida like this.
  12. Erwin Merida
    That's what I was noticing once you start reading the parts description.. I never used rockauto before, going to look into that! Trying to eliminate about 2inches of wheel play! Hahahah
  13. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    Oh man the best part of rockauto is you start collecting fridge magnets.
    THorn, Erwin Merida and jetas like this.
  14. jetas
    Lol the mini fridge in the garage is covered in magnets
    Pearce likes this.
