Which wire is the stock tach signal wire?
Discussion in 'Interior/Electronics' started by toytruk, Sep 13, 2010.
  1. toytruk
    toytruk Enthusiast
    Ontario Canada
    92 xcab
    Ok I'm looking for the stock tach signal wire... Can't seem to find a pinout for this truck at all... Its a 92 22re 2wd pickup with oem tach... Truck has gone through a transormation and now has a 1jz gte motor and trans and I got a digital converter box to convert the tach signal to make it work! Just need the tach signal wire...
  2. project_DragTruck_v2.0
    well, on a stock motor, it's the hot one coming out of the igniter. (white/blk stripe IIRC)
  3. dillinja666
    im confused where you are trying to find the tach signal? behind the speedo or in the engine bay?
  4. toytruk
    toytruk Enthusiast
    Ontario Canada
    92 xcab
    Sorry guys... Behind the tach it goes to plugs that are on the right passenger side... Where the ecu is... I'm trying to find it there... I removed my engine harness and engine and swapped in a 1jz and there were 2 body plugs that remained with the truck... So I assume the wire from the back of the rpm tach goes to one of those plugs that the engine harness went to.... Just don't know Whig plu or wire... Thanks
  5. toytruk
    toytruk Enthusiast
    Ontario Canada
    92 xcab
    Anyone?? Body harness pinout???
  6. dillinja666
    all data says its a black wire that goes from the back of the cluster through connector C2 to the ignitor.
    i would trace from the cluster back, or from the ignitor forward.
  7. toytruk
    toytruk Enthusiast
    Ontario Canada
    92 xcab
    Thanks man... Now were getting somewhere I found out aswell that it is a black wire Aswell... But which connector is c2? The white or grey one by the passenger side?
    Thanks man
  8. dillinja666
    that i dont know, you are going to have to trace it yourself... either use a volt/ohm meter or trace it by hand.
    if you did the jz install this should be easy for you to figure out.
  9. toytruk
    toytruk Enthusiast
    Ontario Canada
    92 xcab
    Haha yeah I did the Jz install but I didn't wire it lol wiring cars up is a bitch lol
  10. Chucky
    Chucky Enthusiast
    Southern Louisiana
    88 pickup reg cab,82 sr5 long bed,93 reg cab sr5
    Hate to dig this up..I recently put back in my sr5 cluster..along with Speedo cable swap.....I’m looking for where the tach wire would be under the hood for a 93... im running a carburetor ..and when I swapped everything I haven’t payed attention to the coil wiring igniter etc. truck was an sr5 and was fully electronic cluster
  11. BatryOpratedBoy
    BatryOpratedBoy Enthusiast
    Fresno. =(
    Brave Little Toaster (Diana) and Salsa Verde (Traction Control)
    If I remember right you can splice it to the green wire coming off the coil.
  12. flacostaco
    flacostaco Toyotaholic
    Corona Southern Cali
    87 pickup
