The Official "Other car wheels on my toyota" thread
Discussion in 'Wheels/Tires' started by SD YOTA, Feb 13, 2011.
  1. Blitz
    Blitz Enthusiast
    Georgia!!
    It's not a Toyota
    Any more? One of my favorite threads on TM.
  2. Bradthreee
    Bradthreee Enthusiast
    Palmdale, Ca
    1990 xcab
    Here's mine on some Crown Vic meshies
    Erwin Merida and twizted1 like this.
  3. SD YOTA
    my truck on C4 vette wheels... aka salad shooters. 16x8.5, 32+ offset (used with 1.25" adapters witch push the wheels out to a -2 offset) mounted on 195/50/16 tires...
    Erwin Merida and smallz like this.
  4. paseobeater
    paseobeater Member
    93 xcab
    I like, this match your truck a little better
  5. SD YOTA
    thanks. im really digging them...
  6. NashMan
    NashMan Toyotaholic
    Vancouver Island, Canada
    94 2wd
    twizted1 likes this.
  7. LilRed93
    LilRed93 Addict
    Spanish Fork, UT
    1993 Pickup
    I like your truck Nash. Very clean and simple. I miss my dirt bike as well.
  8. yotaman95
    yotaman95 Enthusiast
    Cottonwood Heights Utah
    1995 single cab
    Jaybee you have a nasty truck my friend! And your exhaust is perfect! mad kootoes!
  9. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
    Bradthreee, what size tires are you running on your crown vics?
  10. Bradthreee
    Palmdale, Ca
    1990 xcab
    I'm running 205/55-16
  11. 90DailyDriven
    90DailyDriven Veteran
    New Mexico
    90 standard cab 2wd short bed
    Mitsubishi 3000GT rims 16x8 +44
    Upper ball joints would rub on lip of the rim. Had to change uppers to 1995+ 2wd Tacomas. Used Autozone spacers so rear would not run the leafspring mounts. Toyota Prius center caps.
  12. HI_state_toyz
    HI_state_toyz Member
    Oahu Hawaii
    89 single cab pick up
    Is there any other car make rims that dont need to be bore out? Or change anything? Thanks
  13. udream69
    udream69 Enthusiast
    Manchester/London, KY
    1992 Std Cab Toyota
    Here's my 17" Lexus ISF snowflakes. +35mm offset. 7.5" wide. Bores 73.1 so I had to run the bore adapters.
  14. LilRed93
    LilRed93 Addict
    Spanish Fork, UT
    1993 Pickup
    Those Lexus rims are sick! How much they set ya back?
  15. udream69
    udream69 Enthusiast
    1992 Std Cab Toyota
    Reproduction ebay set. Spot on though and the came with center caps for 475 with shipping.
  16. warbird
    warbird Member
    where do you get bore adapters? I just picked up some crown vic cop car steelie 17's and the bore is too large.
  17. yotaman95
    1995 single cab
    Yes where did you get your wheel adapters?!! My miro 398 18x10.5s just arrived and the rears clear the center bore amazing but the front wont fit over the center hub. When I did my research it said our hub size was is 60.1 and like yours udream69 the miro bore is 73.1. Any help would be awesome fellas kinda stuck here!
  18. DJ63
    DJ63 Newbie
    Albuquerque, NM
  19. yotaman95
    1995 single cab
    Ok so if the hub is 60.1mm then my wheels 73.1 hub should fit shouldnt it?
  20. DJ63
    DJ63 Newbie
    Albuquerque, NM
    yes, the problem with mine was that the rim didn't fit over the grease cap so I couldn't get the rim center cap on so I had to use spacers on mine. I have the same size center hub as you as well
