92 yota drop
Discussion in 'Introduce Yourself' started by 92 ridin low, Sep 29, 2012.
  1. 92 ridin low
    92 ridin low Member
    chandler az
    1992 single cab toyota pickup
    its been a long time since i have posted any updates my computer has been laggin but here is what i have done to my yota so far
    i painted the 4runner fenders with a rattle can i think they came out preety good
    i also got a new bed for it
    drove the truck from chandler all the way to union hills
    here is the other truck i got the bed from found it on craigslist
    the guy also threw in some belltech drop shocks for 40 dollars more
    since i dont got a press i used my trucks cab mount and a jack to get the bushing pressed into the shock
  2. NWA STEVE
    NWA STEVE Enthusiast
    missouri
    1987 toyota xtra cab longbed
    I like the look youre doing on this truck
  3. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    any pics with the new bed on yet>?
  4. 92 ridin low
    92 ridin low Member
    chandler az
    got my new l.e.d tail lights the other day it was like christmas all over again
    what you guys think
  5. Da_Roach
    Da_Roach Toyotaholic
    NOVA
    (1) 92 RN80 (1) 2002 RZN150
    I like the tails. I have a set on both of mine. Best taillights I think. What is the plan for the Craigslist truck? Flip or back up DD?
  6. 92 ridin low
    92 ridin low Member
    chandler az
    yea these tailights are the best. i plan on using the other yota as a daily now that this one is gonna start getting bagged
  7. 92 ridin low
    92 ridin low Member
    chandler az
    started putting notches on my truck yesterday getting ready for bags
    had to put the stock taillights on i dint want the leds being held on with zip ties
    hand made c notch
    my buddy trevor welding the notch in
    and shes notched one step closer to having her on the ground pushing pebbles :evil:
  8. 92 ridin low
    92 ridin low Member
    chandler az
    hopefully the round tube comes in this week so the round tube work can be done on saturday
  9. 93_Toy_Mini
    93_Toy_Mini Addict
    Gardnerville, NV
    93 Reg Cab Pickup
    Great work man. I'm digging the color scheme you have going so far.
  10. 92 ridin low
    92 ridin low Member
    chandler az
    thanks man i appreciate the feedback
  11. 92 ridin low
    92 ridin low Member
    chandler az
    got the air tank welded in last week
    its ment to look like the round tube is goin through the air tank
  12. Vytenis
    Vytenis Newbie
    nice bro
  13. dAn-dAn26
    dAn-dAn26 Newbie
    southern California
    props on the clean looking truck man, rims r lookin good and the tails will definitely tie the rear end together.
  14. 92 ridin low
    92 ridin low Member
    chandler az
    got the new battery trays made. Im gonna be running 2 yellow top optimas
  15. Scr8pnyota
    Scr8pnyota Member
    Longwood Fl.
    Looks good man clean Yota. Work is looking clean. I like the way you did the air tank
    tubing.
  16. 92 ridin low
    92 ridin low Member
    chandler az
    next i gotta eliminate the lspv valve
    i want to cut the brake line right after the gas tank and re flair it from there and attach straight to the diff :D
  17. SD YOTA
    you can delete it by connecting the axle line that goes to the T to your supply line, then right under the master cylinder, use a bpv valve from a 84-86 truck... thats where they were on some of these trucks stock. this gets rid of that whole adjustable one.
    i ended up cutting the arm off earlier this week and all the attachments on the axle. works just fine without it.
  18. 92 ridin low
    92 ridin low Member
    chandler az
    im not sure what you ment by bpv valve but this is how i did mine and its been working good so far
  19. 92 ridin low
    92 ridin low Member
    chandler az
    went to the junk yard and pickup another valve braket from another toyota pickup
    i then cut the L valve fitting off the bracket
    then welded both the L fittings together
    then after i eliminated the return line i cut the other line reight after the gas tank
    and rented a flairing kit from autozone to reflair the cut line
  20. Chikn Hawk
    Chikn Hawk Member
    671 Guahan
    94' X-Cab Toy Lux
    Mini is looking good bro. U got specs on how u did the runner lights on stock core? I'm in progress of doing mine but w/o swapping the core support. I got a 90 model yota. LMK
