I did the RIGHT Thing again
Discussion in 'Off Topic' started by TheLoLux, Nov 5, 2012.
  1. TheLoLux
    TheLoLux Toyotaholic
    Simi Valley, CA
    Well about 2 yr ago I can across 2 RHD clip, and I sold one to a friend. And did my swap. Well it was time to do his. So here it is [​IMG]
    He drove the truck down form pismo to the shop Friday night. We started on it sat. after noon. [​IMG][​IMG]
    We started the tar down and got a lot done the frist day[​IMG] [​IMG]
    Do to the v8 swap we chose to pull the cab. [​IMG] [​IMG] by the end of day one we had the old fire wall out [​IMG]
  2. TheLoLux
    Simi Valley, CA
    Day 2 the fun started. He had already strip the RHD fire wall out, so we prep the metal and put the RHD fire wall in [​IMG][​IMG][​IMG]. As I fit the fire wall and welded it in Derrick started on the steering. Sence it a 4x4 the box we got with the clip work, an like mine witch had to be a 2 wheel drive box. By the end of day2 we got the cab back on[​IMG] and Derrick started to wire the truck. Sence the v8 he had a little more wiring and we got rid of the iner fender well so we had to do a wire tuck too. [​IMG]
  3. TheLoLux
    Simi Valley, CA
    Day 3. I start on the front end and Derrick stayed on the wiring. I made so tube supports for the core that bolt in. And mounted 2 4 runner ac fan on the fornt. [​IMG][​IMG]. Then my glass guy cam back with the windshield. I had him rap in the the late model Tacoma gasket. I think it has a cleaner look. [​IMG] Derrick still had a lot of wiring still to do. [​IMG]. So we call it a early day and went and got some beer!!!
  4. TheLoLux
    Simi Valley, CA
    Day four: I got the rest of the front end on and the wiring done and went for a drive tripping people out lol. But Derrick forgot the dash at his house so when he put it on I get some pic of that. But here the rest that I have. [​IMG][​IMG][​IMG][​IMG]
  5. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
    Damn thats killer!! Always wanted a RHD truck, didn't realize it took that much to do.
    Is it still gonna be street legal?.
  6. TheLoLux
    Simi Valley, CA
    Yea it's legal. I did my truck 2 yr ago and went to the CHP and they cleared it.
  7. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    You guys do some quick quality work bro.It would take me a while to get use to that RHD.Turned ot cherry.
  8. dagnisaun
    dagnisaun Enthusiast
    sick 4x4!!
  9. IronNam
    that looks great! :D
    I wanna try that gasket :)
  10. Da_Roach
    Da_Roach Toyotaholic
    NOVA
    (1) 92 RN80 (1) 2002 RZN150
    Thats good to know the tacoma gasket fits on these trucks. Looks like more killer work from Empire. Keep up the quality work.
  11. TheLoLux
    Simi Valley, CA
    Thanks guys.!!!
  12. sikyota
    sikyota Member
    arroyo grande
    90 reg cab
    It's not to bad you get used to it quickly. It just needs final changes to make it more reliable but the engine is coming out and I have LS1 I'm the garage for it
  13. Malessohomegrown
    Malesso,Guam
    Do you know if the Tacoma rubber will work on the 84-88 model windshield?? For sure looks cleaner.
  14. Kahuna
    Kahuna Enthusiast
    AZ
    94 single cab
    Great job on the swap!!! As for the tacoma gasket...any particular years? I would love to replace the molding on my 94's windshield!!!
  15. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    +1...more info on this...please, thankyou.:applause:
  16. TheLoLux
    Simi Valley, CA
    Off a 98 Tacoma
  17. spanks_4
    spanks_4 Enthusiast
    Denham Springs, Louisiana
    Any special trim stuff I need to know when I go order the tacoma rubber piece? Also will it work on the 84-88 pickups? I don't see why it wouldn't, but want to make sure.
  18. TheLoLux
    Simi Valley, CA
    The trim that we use was from and 98 Tacoma my glass guy came in and I showed him want I wanted. he had to pull the glass and take it overnight to glue the rubber on cus it has to wrap around the corners, so it has to sit for 24 hours before you glue the windshield back into the truck. It should work on your truck as long as the top corners are round like the pickup and tacomas
  19. patrickgraven
    patrickgraven Veteran
    Corona CA
    is the tacoma gasket just look better or does it seal better.
  20. TheLoLux
    Simi Valley, CA
    Seal the same
