rear disk conversion
Discussion in 'Suspension/Chassis' started by stimanmark, Mar 14, 2012.
  1. stimanmark
    stimanmark Member
    North GA/South TN area
    93 reg cab, 22re
    I did search on here and havent found a solid answer......what needs to be used do the rear disk conversion?
    Is there a bracket that will bolt up? or will it have to be made? anybody have dimensions? what caliper can be used? what about the e-brake?
    Thank you for your help in advance
  2. TRUCK ACTION
    It's all on this site & others!
    Also Google Toyota rear brake conversion!:cool:
  3. raylcc
    raylcc Addict
    Denver, CO
    Or you could do like I'm planning and install an 8.8:
    http://www.toyotaminis.com/forum/suspension-chassis-40/ford-8-8-install-5308/
    Large disk brakes, a strong diff, easy conversion and Explorers are everywhere, so all the parts are almost certainly going to be at your local u-pull-it junk yard. Another thing is that there is a HUGE aftermarket sway bar available for it. Just my two cents.
    EvoLLove likes this.
  4. stimanmark
    stimanmark Member
    93 reg cab, 22re
    like i said....i have found some info but nothing solid! just some i thinks and.....
    Im actually doing this research for a friend of mine and he's not wanting to go the 8.8 way.....i am on my ranger....but he says he doesnt want to go with the 8.8
  5. TRUCK ACTION
    I've done both the front brake up grade ,& rear conversion on my 88. .
    And I've posted all for others!
    A complete rear axle swap is another way to go ,but you must consider axle withe, drive line connections ( from one make to another), lug patterns.
    Plan out what you want to do & what you are trying to achieve ! All add to your cost!!:cool:
  6. burnzya
    i did a rear disk swap using 87 toyota supra turbo rotors and calipers. i fabricated caliper stands out of some 2"x 1/4 steel. i machined the rotor bore roughly 6mm to fit my axle.
  7. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    cant wait to do mine !
  8. TRUCK ACTION
    That rotor looks to be around 8-9'', still is too small !
    Front I went from stock 9.25'' to 12.19'' & rear is 11.32''!:cool:
  9. burnzya
    :funnyup:
    that rotor only looks small in the 20's
    stock supra rear measures 291mm which is 11.45". if it'll stop a turbo'd supra it'll stop a minitruck. especially if it's a 4 cylinder powering it.
    also if i used mostly stock components the whole swap would have been around $80. doing the a/n fittings cost a bit more.
  10. Dcups
    Dcups Addict
    Seattle
    93 Std Cab chassis/4Runner 2door body
    Burnz wanna make me a set of those Brackets?
  11. bodybagged
    bodybagged Enthusiast
    Mesa AZ
    toyota clipped datsun
    :verdict_in:cookie cutter
  12. V8_TITAN
    Tampa Fl
    89 std cab
    is there such a thing as too small of a disk brake for the rear on these trucks considering they have no stopping power at all from the factory ? lol. but yeah dude hurry up and build some cookie cutter type device to start stamping these out for us : )
  13. 85pickamatruck
    85pickamatruck Veteran
    Seattle
    85' Base
    I agree. How much for a set up? Ill pay for shipping.
  14. 93_Toy_Mini
    93_Toy_Mini Addict
    Gardnerville, NV
    93 Reg Cab Pickup
    Can you say: "Group Buy"?
  15. 93_Toy_Mini
    93_Toy_Mini Addict
    Gardnerville, NV
    93 Reg Cab Pickup
    Actually, I just have some questions if you don't mind answering them. But first let me see if I can figure it out. It looks like you started with two pieces and then you lap welded them. You picked 2"X1/4" because it gave you the perfect width to mount to the the caliper to the axle. You started by making a template, maybe... So is this on your stock axle? No swapping axles or cutting rear diff? Do you think that piece you fabbed up will work on the 89-95? I mean I know the process will work but can I use the same materials of do you think I would have to use different size steel?
    :thinking::doah::thinking:
  16. 93_Toy_Mini
    93_Toy_Mini Addict
    Gardnerville, NV
    93 Reg Cab Pickup
    For someone who likes to misinterpret a so called "negative" comment, you sure are lousy at actually answering some questions. Oops, sorry! That was negative huh? Don't worry, while you busy wasting your time on that reply, I figured it out.
  17. burquescraper
    burquescraper Member
    Charleston sc
    87 xcab 91 rx7 totaled:(
    how much have you figured out and are they for sale my drums can't stop cheese on a hill stock
  18. TRUCK ACTION
    Here's what I did
  19. White Trash
    Sweet setup truck action. What application is the rotor and caliper from?
  20. TRUCK ACTION
    Rear calipers are 79-85 Caddy with e- brake, rotors are 1984 Ford Mustang SVO( SAME CENTER BORE & LUG PATTERN)., the caliper brackets I made ,as no one has them for Ford rotors, & the GM ones( lots out there) the rotors are a smaller center bore ,so machining is need! So when replacement is needed , a extra cost!
    I posted all the info ,part numbers included, on this site !:cool:
