93 toyota pickup,2wheel drive
Discussion in 'Frequently Asked Questions' started by joe barrios, Jan 7, 2011.
  1. joe barrios
    joe barrios Newbie
    Can someone tell me how to replace my burnt-out dashboard lightbulbs? I only have one bulb working at this time....
  2. DionTDE
    DionTDE Addict
    Preston, ID
    93 single cab 2wd
    Yeah it is very simple actually. You need to pull out the entire gauge cluster. There is a piece that goes over the cluster and over the rest of the front of the dash. Remove that piece then there is a couple screws hold the cluster it. On the back side of the cluster the light twists a quarter turn and pops right out.
  3. eurofreak2002
    eurofreak2002 Toyotaholic
    B-town 208
    What he said
    Erwin Merida likes this.
  4. topcop182
    topcop182 Addict
    Colorado Springs Colorado
    1993 single cab 2wd
    yup, not too hard. Just pay attention to how everything bolts together. Take some pictures, it helps!
  5. lifted85
    lifted85 Newbie
    hedgesville wv
    85 xcab
    Yea theyare very simple man. Just go step by step
  6. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    should be lo194 lamps
  7. confused.rat
    confused.rat Enthusiast
    Springdale, Ar
    1993 Pickup Ext Cab.
    how many bulbs are back there? cause mine is pretty dim.
  8. DionTDE
    DionTDE Addict
    Preston, ID
    93 single cab 2wd
    I had 2
  9. Kristian43
    Kristian43 Veteran
    Ventura
    89 Toyota Hilux Dlx
    How do you remove the piece on top of the cluster. The main dash piece. I can't really are where or how it comes off without removing the rest of the dash first??
  10. keckert
    keckert Newbie
    Regina, Saskatchewan
    1989 v6 xcab 2wd pickup
    You have to remove the rest of the lower dash first before you try to remove the dash piece that is around the gauge cluster. Once you do all that and get the dash off from around the gauge cluster, there are like 4 or so sqrews holding the cluster in place. Undo those sqrews unplug everything from the back of the cluster, and then change your bulbs and put everything back together.
