Can someone tell me how to replace my burnt-out dashboard lightbulbs? I only have one bulb working at this time....
Yeah it is very simple actually. You need to pull out the entire gauge cluster. There is a piece that goes over the cluster and over the rest of the front of the dash. Remove that piece then there is a couple screws hold the cluster it. On the back side of the cluster the light twists a quarter turn and pops right out.
yup, not too hard. Just pay attention to how everything bolts together. Take some pictures, it helps!
How do you remove the piece on top of the cluster. The main dash piece. I can't really are where or how it comes off without removing the rest of the dash first??
You have to remove the rest of the lower dash first before you try to remove the dash piece that is around the gauge cluster. Once you do all that and get the dash off from around the gauge cluster, there are like 4 or so sqrews holding the cluster in place. Undo those sqrews unplug everything from the back of the cluster, and then change your bulbs and put everything back together.
