Okay, after doing a bit of reading about on the internet, a mild all motor build will make between 150-190 depending on what parts I choose and what I do to the block/head. I don't think that would be enough power for what I want. I wanted over 200whp, I don't think I will see that without mucho dinero. What about turbocharging?
Sheesh, I could do cheaper with a used F.A.S.T. or Motec system. Does that $900 include the wideband and multi display?
Yes has a small digital control box that you can put any where you want in side the cab.Iteliminates most sensors,distributer,coil.makes it simple.a good alternative to Itvs
Belt drive forced induction sole propane/LPG, unlike gasoline/ petroleum the engine dose not need to have the compression dropped and carb/efi is replaced by the mixer, on sole lpg boost levels can be considerably higher than on gasoline/petroleum and higher power output levels are also obtained without issue to the engine and if somdthing dose go wrong another stock engine is cheap and easy. If you Google lpg supercharger as it might be just an Australian thing to get around certain engine swaps and emission laws but on early Australian made Holden straight six engines more power is able to be obtained this way for less money than any other option as it really is only the matter of fitting the supercharger and the gov gives a rebate for fitting lpg
Or you could go 11:5 compression on some 48mm side drafts and a hot cam skip all the ecu stuff and go old school just making over 200hp on a 22re or22r all motor setup quickly becomes not so street friendly. However building a turbo kit and possibly throwing in some low comp pistions arp studs and h beam rods . Could proably get you there and be decently reliable
Yeah, from the looks of it, it is by far cheaper to turbo this thing than to make a 200+whp all motor engine. I can just FMU it and call it a day. I might still look into that SDS tho, I like the touch screen wideband guage
http://m.youtube.com/#/watch?v=4SO5Rj1_Y9I&desktop_uri=/watch?v=4SO5Rj1_Y9I I hope that link worked Seriously don't dismiss the ease of a supercharger as no inlet or exhaust modifications are needed it is purely the belt drive, try youtube or Google supercharged 202 Vauxhall lpg. There are mixers available to fit Holley, (lpg holley) Google that as well.
I wouldn't try to build a 200hp 22r.... Unless you got the cash and just buy a lc race motor! But really, keep it simple, do the basics, and try not to spend too much money. My hybrid is fast for a 22r, but my truck is still pretty pitiful against pretty much everything. If I was to do it again, a 302 v8 swap or a mild 22r build. The four banger just doesn't have the displacement for an "all out" motor. 7500rpm, compression and twin carbs will make 200hp. Not easy or cheap. Hope it helps. Oliver R
I am currently building a 1.6l Honda turbo engine that will easily see over 300whp. Why won't this 2.4l make over 200whp? I will just boost it.
I know how awesome LPG is but I don't think with will suit my needs well. Availability of LPG is not as easy or cheap in the US. It is great for off road applications, but I am looking to use this truck as my track bike hauler and work blaster.
Our standard petrol is 91 octane and is around the same price per litre as a gallon of gas in the US, lpg is around half the price of petrol and I was once told lpg is kind of like 120 octane which allows far higher compression or boost than pump petrol/gas. Under Australian emission laws efi is not allowed to be removed from car or engine unless converting to sole lpg and certain engine swaps are only legal when sole lpg, hence the 4 litre sohc straight six Australian made ford falcon engine in 1tuf65 mustang. The engine produces some 822hp on the dyno 9's on the quarter mile and is street legal still under the very strict Australian modification laws, all this from an old engine out of a taxi that was lucky to be 200hp, but 40psi of boost helps
our trucks made for towing and hauling. not popping vtec and hitting 9k. we max out around 6ish depending. boost is a good way to go.
Sidedraft independent throttle bodies I always wanted to run these. But idk what it would take to get them into my truck. Sidedraft Throttle Body Kit(45mm) - 20R/22R/RE/RET Sidedraft Throttle Body Kit(45mm) - 20R/22R/RE/RET
Yeah, from the looks of it.....22re's are trash for anything but being reliable. I think I will just talk to my importer friend and try to get a 2jz and a t56 and just rebuild the engine back to stock for now. I am not going to waste money on a trash powerplant I can't make any real gains on. 80% over stock just isn't good enough. On a cheap boosted build on most other four bangers, I easily net over a 150% gain in power. Now, the question is, what will I have to do to the chassis to handle a 4-500whp 2jz? Any other good/cool yota swaps out there? Are there any manual transmissions that bolt up to the LS400 v8? I have one of those sitting in the yard and the engine is free.
Done a bit of google research, the 1UZFE engine out of the LS400 makes 256hp/260tq. The answer was in my backyard the whole time. I will need the Quantum-Auto adapter kit and a w58 trans. After that, I will need to upgrade gearing a bit and get a driveshaft made. I think I will try to run some sort of standalone ecu with it, just to keep the complications of converting crap out of the picture.
Just remember that the w58 trans can only handle so much power. I have a friend with a boosted toy broke 2 trans already hes at 310hp to the crank. And my 305 sbc motor snapped my 4speed like butter.
I am going to leave it stock. That is more power than I was going for and should be more than adequate to completely destroy a set of tires if I want it to. I was thinking of a 6-speed trans but I don't think it is worth the money for what I am going for. For about the same price as a decent little 22re N/A build, I can swap in a 1UZ FE with manual trans and FAST for tuning. The only extra costs is mounting, radiator and driveshaft. Maybe diff changes as well.
